1985 xj6
Old May 25, 2011 | 06:59 AM
TIMMYG's Avatar
Default 1985 xj6
im having a hard time removing the radio from my xj6 it seems to me that there might be speacial tool needed to remove the nuts on the faceplate behind the heater knobs ? i think i need a two headed screwdriver ?any help with this would be great
Old May 25, 2011 | 08:28 AM
Doug's Avatar
I'm pretty sure you can buy special tools for the notched radio nuts but you won't need to.
Take a flat blade screwdriver and engage it into a notch then use a heavier tool....small hammer if you have one...to gently break the nut free by tapping in a counter-clockwise position.
Welcome to the group, by the way.
Old May 25, 2011 | 11:51 AM
Hi Timmy, welcome on to the forums....
Thanks go to Doug for the welcome and the assist......check out your relevant car section for furtherr results
You might find the off topic good for fun, maybe check out the mug shot thread and add yours?
Some really good guys and great techs, top vendors offering good pricing levels and great service, and more to come....all good
In the meantime I've upgraded you manually to full forum access so you can better view the site
Old May 25, 2011 | 01:31 PM
Nevette's Avatar
Timmy, welcome to the forum. Hope you got your radio out. Enjoy your time here and when you can post a picture or two of your XJ6.
Old May 26, 2011 | 05:54 AM
Welcome to the forum Timmy,
Don't you know any chavs? They would have the radio out in a second!
Old May 29, 2011 | 10:25 AM
TIMMYG's Avatar
Default radio
thanks for the advice doug !!! i got the nonworking radio out , but now i have a problem with finding the fuse for the radio ? my electrical prinyout says it is an inline fuse behind the radio ? and i dont see one there can you tell me where i can find the fuse ?
Old May 30, 2011 | 04:53 PM
TIMMYG's Avatar
Default radio fuse ?
im looking for the inline fuse for my radio , in my1985 xj6 , the diagram says its brhind the radio , but i cane find it ?
Old May 30, 2011 | 05:24 PM
Gus's Avatar
Gus
Hello and welcome to jaguarforums.com.
Old May 30, 2011 | 08:06 PM
Doug's Avatar
The fuse is usually in the area of the left ashtray. If you remove the ashtray and ashtray bracket you should be able to root around in there and find it.
There are usually two radio fuses: 12v constant and 12v switched. They should both be in the same area, along with the power seat fuse. Silly location....one of Jaguar's dirty little tricks. On my car I extended the wiring so the fuses could be located in an easier to reach location.
Old May 31, 2011 | 06:11 PM
TIMMYG's Avatar
Default fuses?
thanks doug i found them . now my new radio is working fine!!! thanks for the info .
i can now move my attention the side fender lights ,they are amber lights on the front corner of the fender .i found the fuses and they are good but i have no power at the lightbulbs?sooo the fun begins,
Old May 31, 2011 | 07:13 PM
Doug's Avatar
Check/clean the bullet connectors which sorta poke out through the opening on each nner fender...a bit forward of where the diagonal fenders braces attach.
Also, on the back of each marker lamp....you can see if you look up inside the fender...you'll observe the 1940's method of grounding the lamp. Clean the grounds.
While you're at it remove the head lamp fuse box (once small bolt at the bottom), lift it away an inch or so, and clean all the bullet connectors you find nesting there.
If you're really ambitious just spend a day going from bumper to bumper clean every connecter, relay terminal, fuse end cap, fuse clip, and ground point that you can put your hands on. You'll be preemptively correcting about 90% of the notorious Lucas electrical problems
King Charles
Oct 16, 2015 01:25 AM
trickeyM
Oct 4, 2015 05:43 PM
wonderwire
Oct 4, 2015 05:41 PM
baskervillema
Oct 1, 2015 06:43 PM
black5litre
Sep 27, 2015 03:10 PM
