2004 Xj8 gear shift problems
Old Oct 1, 2018 | 12:38 PM
Teresa Joyner's Avatar
Default 2004 Xj8 gear shift problems
I own a 2004 XJ8 and the car won't drive when you put the car into reverse or drive. The issue came when the bolt came loose and now it won't move at all. We're not sure if the transmission is off. Can you please assist?
Old Oct 1, 2018 | 01:11 PM
S-Type Owner's Avatar
Welcome, Teresa. Your problem is, I believe, fairly common with the ZF automatic transmission that your car comes equipped with... There are two bolts that attach the cable linkage to the transmission housing; these small bolts can come loose and the car will not move from park into the forward or reverse gear ranges. What gear does your car show illuminated in the shift quadrant when you move the level from park? Or put another way, does "P" stay lit when you shift into "R" or "D"...?
Old Oct 1, 2018 | 01:37 PM
Welcome to the forum Teresa,
Follow this link
https://www.jaguarforums.com/forum/x...-x350-x358-28/ to the X350 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the US Lower Atlantic Region forum by following this link https://www.jaguarforums.com/forum/usa-lower-atlantic-nc-sc-fl-ga-66/
Enjoy the forums.
Old Oct 1, 2018 | 02:59 PM
While my husband was tightening the screw it was illuminated in drive, but when he turned the bolt it moved the gear into park and it wouldn't shift. I turned the car off and it reset back to park and now it's back to gears functioning, but it still won't go in reverse or drive. He only turned one bolt.
Old Oct 1, 2018 | 04:13 PM
Daf11e's Avatar
Welcome aboard Teresa.
Old Oct 1, 2018 | 04:25 PM
Perhaps Graham can move this thread to the X350 Forum before it evolves into a technical discussion in the New Members area... (part of which is my fault).
Old Oct 1, 2018 | 04:44 PM
o1xjr's Avatar
Welcome to the forums.
Old Oct 1, 2018 | 05:46 PM
I've COPIED the relevant posts to a new thread in X350 forum:
https://www.jaguarforums.com/forum/x...oblems-208807/
The technical discussion should continue there and not in this Intro thread.
Old Oct 2, 2018 | 02:50 AM
Welcome to the Forums.
Old Oct 2, 2018 | 03:44 AM
Welcome to Jaguar Forums Teresa,
Old Oct 2, 2018 | 06:52 AM
welcome to the forum- enjoy!!!
boatus123
Oct 22, 2020 07:11 PM
2jags1garage
Mar 16, 2017 09:16 PM
brianxj8
Jun 22, 2014 07:47 PM
boatus123
Jan 9, 2014 07:45 AM
Terry H
Aug 6, 2013 03:02 AM
