2005 xjr stuck in park !
Old Mar 30, 2014 | 11:32 PM
Mmj's Avatar
Mmj
Default 2005 xjr stuck in park !
Last week I jump in my Jag to go to an appointment and it would not shift out of park this happened when I was running late ,also happened after I was bragging to a bunch of friends that my car looks beautiful has no electrical issues and I like it much better than my same year S500 that one of the guys has . I removed the top wood cover and with a screwdriver turned screw type manual override and I am able to drive it . the P,R,N,D , sport,and traction mode light up in the greenish color none on the left side of the J gate light up also the sport , and traction doesn't seem to be working . I tried replacing the BLS and nothing ,also I get the beeping noise when I try and move it out of park with the ignition off .I appreciate any help , I love this car and would hate to give it up .
Old Mar 31, 2014 | 02:46 AM
Welcome to the forum Mmj,
The transmission selector lever Interlock Solenoid is controlled by an input from the brake pedal switch through the CAN bus. If you have already replaced the Interlock Solenoid, the brake pedal switch must be suspect. You should post this issue in X350 tech section for advice from members with the same model.
Follow this link XJ ( X350 & X358 ) XJ6 / XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum to the X350 forum for help, advice and information.
You can also visit the US North East Region forum by following this link North East US - ME NH VT MA RI CT NJ NY PA - Jaguar Forums - Jaguar Enthusiasts Forum
Enjoy the forums.
Old Mar 31, 2014 | 06:06 AM
welcome to the forum, you'll find plenty of info and support here simply follow the links Graham has provided - enjoy!
Old Mar 31, 2014 | 07:26 AM
Schwabe's Avatar
welcome and enjoy the board
Old Mar 31, 2014 | 08:43 AM
Mmj's Avatar
Mmj
I tried replacing the brake light switch , and nothing changed ,that's the only part I tried so far
Old Mar 31, 2014 | 01:40 PM
I'd have gone for Interlock Solenoid first and then Brake Light Switch. More Interlocks fail across the Jaguar models than Brake Light Switches.
With a correctly functioning Interlock ON, you shouldn't be able to move the transmission out of Park with the ignition OFF.
Old Mar 31, 2014 | 08:50 PM
Welcome to Jaguar Forums Mmj,
Old Mar 31, 2014 | 11:04 PM
Don B's Avatar
Welcome Mmj,
I'll see you in the X350 forum!
Cheers,
Don
Old Apr 1, 2014 | 01:46 PM
Mmj's Avatar
Mmj
It doesn't shift out of park whether the ignition is on or off the only way I can move it is with a screwdriver and the wood cover off , im going to ck the solenoid to see if it gets power and ground
Old Apr 1, 2014 | 06:59 PM
Helpful_information
Rlover
Mar 30, 2016 10:04 PM
neruda
Oct 18, 2015 01:19 PM
KarimPA
Sep 12, 2015 08:15 AM
metalmarty
Sep 11, 2015 07:05 AM
AL NZ
Sep 4, 2015 08:39 PM
