98 xj8
Old Mar 17, 2014 | 10:26 AM
cselix1's Avatar
Default 98 xj8
The low oil pressure light came on and I wont start. I had it towed home.Where do i start?
Old Mar 17, 2014 | 10:40 AM
Welcome to the forum cselix1,
An unfortunate incident but a wise choice to have it towed. First thing to check is whether it is genuinely low on oil or it's a faulty sender. Any horrible noises before you stopped the engine?
Follow this link XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum to the X308 forum for help, advice and information.
You can also visit the US Lower Atlantic Region forum by following this link Lower Atlantic - NC SC FL GA - Jaguar Forums - Jaguar Enthusiasts Forum
Enjoy the forums.
Old Mar 17, 2014 | 10:44 AM
welcome to the forum! You'll find plenty of info and support here simply follow the links Graham has provided - enjoy!!
Old Mar 17, 2014 | 10:50 AM
cselix1's Avatar
no noises, Oil is full , Just had Oil.Change. 300 miles ago,seams to not have spark, I am alone and can not check for spark with screwdriver today.
Old Mar 17, 2014 | 10:58 AM
No metallic clattering noises is very good news!
The Oil Pressure Sender is right next to the filter so it could have been disturbed / damaged during the recent oil change.
I recommend you start a thread in X308 tech section outlining what you have checked so far. Members with the same model will be able to help.
Old Mar 17, 2014 | 11:14 AM
jerry_hoback's Avatar
Welcome. I hope theres an easy fix for you. Theres lots of help here, just ask. Good luck!
Old Mar 17, 2014 | 11:43 AM
SNG Barratt USA's Avatar
Former Sponsor
Welcome to the forums!
Old Mar 17, 2014 | 12:21 PM
cselix1's Avatar
Im sory, i am so new to this. i can not find x308 tech section. i have a 98 XJ8 none L.
Old Mar 17, 2014 | 08:04 PM
Don B's Avatar
Hi cselix1,
Welcome! The Jaguar factory model code of your 1998 XJ8 was "X308," the V8 successor to the '95-'97 6-cylinder X300.
To get to the correct forum for your car, left click the FORUMS button at the upper left hand corner of this page;
In the drop down menu that appears click Jaguar Models (Modern);
And in the new menu that appears to the right, click XJ (308) XJ8 / XJR
Start a new thread in that forum describing the issues you're having with your car and lots of friendly folks will do their best to help.
Cheers,
Don
Old Mar 17, 2014 | 09:44 PM
Welcome to Jaguar Forums cselix1,
Old Mar 18, 2014 | 07:58 AM
Schwabe's Avatar
welcome and enjoy the board
Old Mar 18, 2014 | 12:26 PM
cselix1's Avatar
I had it towed to a shop and found out I have no compression.Anyone need a parts car? Brand new tranny last year.
Old Mar 18, 2014 | 01:44 PM
Absolutely zero compression on all eight cylinders?
Old Mar 18, 2014 | 07:08 PM
Hi and welcome aboard Jaguarforums.
If you need any help with the site moving forward, please just ask any moderator or veteran member and we'll be glad to assist.
search facility etc, can be found here within the following link Helpful_information
I've manually upgraded you to Full forum access so you can better view the site and all its features, so please Jump on in and enjoy the site........
Old Mar 19, 2014 | 08:18 AM
cselix1's Avatar
I m not convinced this shop did a good job. I am having it towed to another shop.Anyone have experience with Thoroughbred motors in Sarasota Florida? He thinks it might be the timing guides or a fuel pump. He's going to open it up for free and let me know. I sorry i dont have a lot time right now to learn this site, but I will figure it out and post in the correct spots when I do.
Old Mar 19, 2014 | 08:43 AM
I m not convinced this shop did a good job. I am having it towed to another shop.Anyone have experience with Thoroughbred motors in Sarasota Florida? ...........
I've copied your post to Lower Atlantic Region forum to try and get advice about Thoroughbred Motors from members in FL.
Here's a direct link to it:
https://www.jaguarforums.com/forum/l...lorida-114003/
I hope this second shop is better.
Old Mar 19, 2014 | 08:50 AM
cselix1's Avatar
The more reading I do here, the more amaized I am at the little things that could be wrong.I love the car and want to drive it. I just hope the motor isn't blown or it will cost to much to fix.
Old Mar 19, 2014 | 09:10 AM
I hope so too.
Please post back with what the second shop finds and recommends.
magmedia
Oct 8, 2015 03:28 PM
freddieg
Oct 6, 2015 11:23 AM
mat32essex
Oct 3, 2015 04:12 PM
kingdom worker
Oct 2, 2015 05:43 AM
donald ebanks
Sep 30, 2015 07:08 PM
