Andrew David smith
Old Mar 22, 2019 | 01:11 AM
Andrew Smith's Avatar
Default Andrew David smith
Hi stype turns over will not start did av a code was malfunction was starting ' OK before. The fuel gauge is all over the place. battery OK ' changed fuel pump sometimes boot won't open macanic said he thinks it's ecu but all sudden won't start it's sitting on drive know ' it's lovely jag shame can enyone help its playing on my mind
Old Mar 22, 2019 | 01:46 AM
Welcome to the Forums.
The S Type Tech Section will have suggestions/answers, BUT, the year of the car ,engine type and size will be needed to sort it.
Good luck.
Old Mar 22, 2019 | 02:01 AM
Daf11e's Avatar
Welcome aboard Andrew.
Old Mar 22, 2019 | 03:18 AM
Welcome to the forum Andrew,
I can see you have posted about this problem in the S-Type forum (
https://www.jaguarforums.com/forum/s...-start-215366/ ). The 'HOW TO' thread at the top of the S-Type forum is a good place to start for information on regular issues.
I have added vehicle details to your forum Signature to help others to give relevant advice. If you wish to amend this, go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
You can also visit the UK & Eire Region forum by following this link
https://www.jaguarforums.com/forum/uk-eire-68/ to find other members in your region.
Enjoy the forums.
Old Mar 22, 2019 | 05:10 AM
o1xjr's Avatar
Welcome to the forums.
Old Mar 22, 2019 | 06:12 AM
Old Mar 22, 2019 | 09:36 AM
Hello, Andrew,
Old Mar 22, 2019 | 10:59 AM
Welcome to Jaguar Forums Andrew,
Old Mar 22, 2019 | 12:36 PM
S-Type Owner's Avatar
From one S-type owner to another... Welcome. The S-type forum is populated with a very friendly group and contains a wealth of knowledge. That said, you need to work with us a bit. What is the year and model of your S-type and what is your location? Also, please also break your post down into sentences as your "ee cummings - stream of consciousness" style of writing posts will cause readers some frustration; this will then limit the number of responses to your inquiry.
johnjo
Sep 7, 2016 07:27 PM
Spikepaga
Jul 25, 2015 06:49 PM
charles smith
Oct 2, 2014 07:27 PM
charles smith
US Lower Atlantic
Sep 30, 2014 06:43 PM
ajjanoski
Sep 6, 2011 07:51 PM
