Bonnet airbag on XK 2006
Old Jan 31, 2023 | 03:55 PM
preece230's Avatar
Default Bonnet airbag on XK 2006
Hi all I have replaced the 2 front pedestrian sensors by the radiator and had them reset by the dealer but they said that the RH bonnet airbag sensor was faulty, my question is is that sensor built into the airbag so do I replace the RH airbag and how easy is it to remove, it looks fairly simple and do I disconnect the battery to do this as worried if it will go off
Old Jan 31, 2023 | 11:45 PM
Daf11e's Avatar
Welcome aboard.
Old Feb 1, 2023 | 12:16 AM
Welcome to the Forums.
A re-ask in the Tech Section will answer that.
XK8 (X100) for the steel bodied car, up to 2006ish.
XK (X150) for the Alloy bodied beast, 2006ish onward.
Good luck.
Old Feb 1, 2023 | 01:01 AM
preece230's Avatar
Hi guys thanks for being a member, how do I ask the question in the tech section
Old Feb 1, 2023 | 02:31 AM
Pick YOUR model, as said.
Go to:
https://www.jaguarforums.com/forum/xk8-xkr-x100-17/ STEEL bodied beast
https://www.jaguarforums.com/forum/xk-xkr-x150-33/ ALLOY bodied beast.
Open the section, look at the LEFT column, and in RED, "START A NEW THREAD" away you go.
Have fun
Old Feb 1, 2023 | 03:11 AM
Welcome to the forums preece230,
The PPS (Pedestrian Protection System) on European market specification XK's can be a real pain. A regular issue is failure of one or both of the two sensors behind the front bumper. You are really unluckly to have a bonnet deployment airbag fault. I'll not go into a detailed discussion here (that's one for a new thread in X150 forum) but you should always disconnect the battery before working on any airbag circuit and give the capacitors time to discharge.
Follow this link https://www.jaguarforums.com/forum/xk-xkr-x150-33/ to the X150 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/ to find other members in your region.
Enjoy the forums.
Old Feb 1, 2023 | 06:20 AM
welcome to the forum
Old Feb 1, 2023 | 07:52 AM
Welcome to Jaguar Forums preece230,
Old Feb 1, 2023 | 09:47 AM
Hello,
Hoppyda
Nov 6, 2020 09:03 AM
Reet White
Jul 27, 2017 09:45 AM
Parmjit Chohan
Dec 15, 2015 06:50 PM
v8mgbgt
May 21, 2012 04:19 PM
v8mgbgt
May 21, 2012 04:15 PM
