Compressor Wiring Harness
Old Oct 14, 2017 | 02:52 PM
daytonaxj6's Avatar
Default Compressor Wiring Harness
I'm trying to find a compressor wiring harness (DAC1408) for an XJ6 Series 3 (1984) 4.2 liter. I've tried Welsh enterprises, Britishwiring.com, Ebay, EverydayXJ and found nothing. A used part in good condition would be great. Does anyone know if there's a way to fabricate this part? Any help would be awesome.
Old Oct 14, 2017 | 05:28 PM
Welcome to the forum daytonaxj6,
Most suppliers list this part as NLA (No Longer Available). If you want to extend your search to other countries:
1. Bavaria
www.carparts-pros.com/page_1_3.php#oeformo
2. Australia
www.prestige-spares.com.au/xjrangeaircon2.html
Follow this link https://www.jaguarforums.com/forum/x...s-i-ii-iii-16/ to the XJ6 & XJ12 Series I, II & III forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the US Lower Atlantic Region forum by following this link https://www.jaguarforums.com/forum/usa-lower-atlantic-nc-sc-fl-ga-66/
Enjoy the forums.
Old Oct 14, 2017 | 07:35 PM
I'm a bit surprised that EverydayXJ.com doesn't have this part! There must be a great need for it!
Anyway, I'll look for you over in our Xj6 section where Graham has directed you.
Old Oct 14, 2017 | 09:06 PM
Daf11e's Avatar
Welcome aboard.
Old Oct 14, 2017 | 11:03 PM
o1xjr's Avatar
Welcome to the forum.
Old Oct 14, 2017 | 11:58 PM
Doug's Avatar
Fabricating a functional equivalent would be easy. Duplicating the original exactly would be more difficult. Finding the connector for the 3-prong thermal fuse might be a problem
Old Oct 15, 2017 | 12:10 AM
Doug's Avatar
Or maybe not....
GM A/C Compressor Thermal Limiter Fuse Wiring Harness Connector Housing Shell | eBay
And here's the compressor connector
GM A6 AC Compressor Washer Fluid Repair Pigtail - The Repair Connector Store
Now you'll just need to find the pin connector and boot for the superheat switch at the rear of the compressor
Old Oct 15, 2017 | 09:31 AM
Old Oct 16, 2017 | 06:19 AM
Welcome to Jaguar Forums daytonaxj6,
Old Oct 16, 2017 | 06:20 AM
Welcome,
Looks like Doug has you sorted.
Old Oct 21, 2017 | 01:45 PM
daytonaxj6's Avatar
I found a used one at Jagbits. Never found a new one. Seems like someone should make this part, since the AC will not run otherwise. I bought an AC upgrade kit for $1000. Even the owner didn't know where to get the AC compressor wiring harness.
Old Oct 21, 2017 | 01:51 PM
Doug's Avatar
Lack of demand, no doubt.
It's a very simple harness. Unless absolute factory correctness is desired, the fastest, easiest fix is to simply make a new one yourself or repair the old one...which I suspect most people do.
Old Oct 21, 2017 | 03:01 PM
I found a used one at Jagbits. Never found a new one. .....
Not even the supplier in Germany I put in post #2?
