David
Old Dec 15, 2021 | 07:43 AM
DavidJChristopher's Avatar
Default David
Hi there
I am new to this forum.
I have a 2005 XK8 which has been left for a time. The battery went flat. I fitted a new one but the car won't start. I'm thinking it's the immobilizer (UK model) but cannot remember how to reset this. I recall a reset being necessary once before and maybe turning the key one way or the other a few times.
Any help gratefully received.
Thanks in anticipation.
Old Dec 15, 2021 | 08:23 AM
Hello, David,
Someone will be along shortly to direct you to the correct section where you can find help for your battery problem.
Old Dec 15, 2021 | 12:32 PM
Originally Posted by LnrB
Hello, David,
Thank you very much. I'm a little confused about how this all works.
Old Dec 15, 2021 | 01:00 PM
Welcome to the forums David,
I'd be very surprised if it is the immobiliser but here is the location behind the trim panel:
Follow this link https://www.jaguarforums.com/forum/xk8-xkr-x100-17/ to the XK8/XKR forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the Europe Region forum by following this link https://www.jaguarforums.com/forum/europe-42/ to find other members in your region.
Enjoy the forums.
Old Dec 15, 2021 | 02:13 PM
Thanks for this. Possible since the fuel wasn't getting through.
Is this the same as the immobiliser to prevent theft though. I thought UK models had this fitted.
Thanks again.
Old Dec 15, 2021 | 02:40 PM
Welcome to the forum David,
I've copied your post to the tech section for a better response, you can follow this link to find it https://www.jaguarforums.com/forum/x...-start-254381/
Old Dec 15, 2021 | 02:49 PM
Old Dec 15, 2021 | 03:22 PM
Daf11e's Avatar
Welcome aboard David.
Old Dec 16, 2021 | 01:17 AM
o1xjr's Avatar
Welcome to the forums.
Old Dec 16, 2021 | 03:43 AM
Welcome to the Forums.
Old Dec 16, 2021 | 05:37 AM
Thanks again.
If you refer to the security system, it will stay set even if the battery is removed and then replaced. As you must have entered the vehicle and it hasn't triggered the alarm, this must have been deactivated with either remote or key.
My next thought would be the chip in the key is not being picked up by the transponder on the ignition switch. This was a common fault on XJ40 but is not unknown on X100.
David Martin-goff
Sep 13, 2020 05:38 PM
David J. Lemos
Sep 4, 2019 02:07 AM
daddyo
Jan 2, 2017 10:03 AM
avt007
Memorial Section
Dec 5, 2014 08:45 PM
Jac-in-a-Box
Nov 20, 2012 01:41 PM
