Error codes...Now what?
Old Aug 27, 2012 | 03:56 PM
98jagxj8's Avatar
Default Error codes...Now what?
Hi, I've got a '98 XJ8 and it has been sitting for sometime. I just replaced all spark plugs. I'm now getting codes P1000 / P1643, both pending. Car will not start. I did add a fuel stabilizer bout a month ago, and when I was doing plugs I noticed the throttle body had cruddy gas laying in the bottom. Anyone have ideas as to what I should do with codes?
Old Aug 27, 2012 | 04:16 PM
98jagxj8's Avatar
Sorry for jumping in so quickly... I live near Kansas City, mo. I have a '98 XJ8 apprx. 68,000 miles. I've been visiting this site for sometime now, but just registered
Old Aug 27, 2012 | 04:49 PM
terry10's Avatar
Hi 98jagxj8 your code P1000 is Engine Control Module internal error and code P1643 is Fuel Pump Motor circuit low input. I hope this helps you.
Old Aug 27, 2012 | 05:18 PM
Gus's Avatar
Gus
This link to your codes should help http://www.jagrepair.com/images/Auto...%201997-99.pdf As for the P1000 that is an on board system check so for now just ignore it. The P1643 is a when an ECM fault is detected and limits the throttle to restricted performance.
I am thinking that you have been trying to start this car and caused the battery to go well below normal and that will cause many faults so for now I would say let it go for the moment. Your car is equipped with a Nikasil engine and that will cause a no start situation due to the lack of compression. This link: JagRepair.com - Jaguar Repair Information Resource will help you with a no start situation and near the end of it you will find information related to Nikasil .
If when attempting to start your car and the engine is spinning like it has no compression then you have a cylinder washing issue and the procedure will help.
Old Aug 27, 2012 | 06:16 PM
Welcome to the forum 98jagxj8,
Sleeping cats need to be woken up carefully!
Excellent advice from Gus on the codes and loss of compression.
In addition, follow this link XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum to the XJ8 section for help and advice.
Please also visit the Mid West US Region section https://www.jaguarforums.com/forum/m...n-mo-oh-wi-39/ for other members and events in your region.
Hope you get the XJ8 running soon. Enjoy the forum.
Old Aug 27, 2012 | 06:48 PM
Hi 98jagxj8 & welcome aboard, good to have you here with us
you've already been offered some of the best advice around.......good luck
Helpful_information
Why not drop in and visit the regional section for your area?
Old Aug 27, 2012 | 08:36 PM
98jagxj8's Avatar
Thank you all for your wonderful support. As I said earlier I've been coming to this forum and using all your great advice. Everyone seems so thorough. Thanks again & I'll keep you posted. I have really missed driving her
Old Aug 28, 2012 | 09:15 AM
Old Aug 28, 2012 | 05:50 PM
98jagxj8's Avatar
Thanks to all the Administrators. I've been trying to find the signature update but haven't found. maybe the actual names are different than the ones you stated GGG?
Old Aug 28, 2012 | 06:03 PM
Click on the User CP button (circled in RED) on the left of the black menu bar and then on the Edit Signature option (circled in BLUE) under Settings & Options. Enter your details in the dialogue box and press the Save button below the box:
If a picture is worth a thousand words, this should get you there!
Old Aug 28, 2012 | 09:08 PM
98jagxj8's Avatar
thank you GGG for explaining it to me like I'm a 3 yr. old.
much appreciated
ricwel
Jun 23, 2023 05:14 PM
magmedia
Aug 15, 2019 08:54 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
Poet
Oct 2, 2015 09:00 AM
Collector1
Sep 28, 2015 03:52 AM
