Help please
Old Aug 8, 2020 | 10:52 AM
Raver83v2's Avatar
Default Help please
2003 s-type 2.5 v6. Been sat a while on tye drive as not used due to furlough. Went to start today but battery dead. Jumped car and ran for 1 hour. Ideling revs seemed high. Switch off as assumed 1 hour running would of recharged battery enough for a restart. Turned engine off and attempted restart. Ignition lights as normal but wouldnt tick over. Stating parking brake fault, DSC unavailable and engine faults. Due to have an OBD read tomorrow but can anyone shed any light? Car has a clean MOT and used to be run daily prior to march.
Old Aug 8, 2020 | 01:16 PM
NBCat's Avatar
What is the battery voltage across the terminals with the ignition in the OFF position when read with a voltmeter? The vehicle requires a minimum of 12.6 volts for all systems to function normally.
If the voltmeter shows less than 12.6 volts, charge the battery for six hours at 2 to 5 amps, then retest. If voltmeter still indicates less than 12.6 volts, the battery is suspect and should be replaced. Many of the electrical 'gremlins' chased across these forums are the result of a failing or weak battery.
Old Aug 8, 2020 | 02:40 PM
Welcome to the forums Raver83v2,
Before looking for more complicated (and expensive) possible causes, I'd have the battery recharged/tested. If the car has been standing since the start of lockdown the battery is likely to be beyond recovery.
Follow this link https://www.jaguarforums.com/forum/s...ed-v8-x200-15/ to the S-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/ to find other members in your region.
Enjoy the forums.
Old Aug 8, 2020 | 03:55 PM
Old Aug 8, 2020 | 05:46 PM
Daf11e's Avatar
Welcome aboard.
Old Aug 8, 2020 | 10:42 PM
Welcome to the Forums.
Old Aug 9, 2020 | 06:18 AM
Welcome to Jaguar Forums Raver83v2,
Old Aug 9, 2020 | 06:25 AM
o1xjr's Avatar
Welcome to the forums.
Old Aug 9, 2020 | 08:53 AM
Hello,
Old Aug 9, 2020 | 03:21 PM
S-Type Owner's Avatar
rom one S-type owner to another... Welcome. The S-type forum is populated with a very friendly group and contains a wealth of knowledge.
Do heed NB Cat's suggestion above.
QueenSuga
Oct 27, 2021 03:15 AM
Glenn Franks
Jun 17, 2018 09:27 AM
Mark Benton
May 28, 2018 04:06 PM
jolibee
Aug 23, 2017 05:52 AM
sueneric
Aug 28, 2014 11:49 AM
