Manually opening trunk
Old Jun 19, 2012 | 11:12 AM
GaryBHigbee's Avatar
Default Manually opening trunk
Hello out there. I am new to Jaguar and have a great need for some advise.
I have a 1999 XK8 and foolishly allowed the battery to die on me. I only have one key, the black one. I was advised by the local dealer to insert the key into the small hole on the rear of the car. When I insert the key, it will not turn right or left. It goes in, leaving about 1/4" showing. I did not purchase the car locally, however I was allowed to talk with a dealer mechanic who advised that I try pushing on the trunk a bit, however that did not help. I also tried spraying some some lubrication into the hole and that also did not help.
Any suggestions would be greatly appreciated. Thanks in advance.
Gary
Old Jun 19, 2012 | 11:48 AM
ooootis's Avatar
Will it unlock the doors? Welcome to the forum, you'll find plenty of help in the car specific forum folders. If it unlocks the door it may need to be lubbed or your not inserting it all the way. Either way if you can get the hood open on the left side of the engine compartment there is a provision for an external battery source. I don't recommend jump starting the car from there but you can apply 12 volts to unlock the trunk.
If you have the owners manual, provided it's not locked in the trunk, it does give a very good outline for this procedure.
Old Jun 19, 2012 | 11:49 AM
Excellent advice above.
Old Jun 19, 2012 | 02:02 PM
Gary,
+1 to ooootis advice.
For the procedure, go to the XK8 FAQ's using this link:
https://www.jaguarforums.com/forum/x...ts-data-29800/
Scroll down to the pic by Paul Pavlik showing where to connect leads in the engine compartment to charge the battery.
Good luck.
Old Jun 19, 2012 | 02:16 PM
Dear ooootis, thanks for your advise. I have downloaded an owners manual and other publications, however I cannot find the information on applying 12 volts to unlock the trunk. Can you please point me in the right direction. Much thanks.
GaryBHigbee
XK8
Old Jun 19, 2012 | 02:28 PM
Originally Posted by GGG
Gary,
Good luck.
OK, I think I have it. I should be able to connect a 12volt, quick start battery charger to match the picture and that should be enough to allow activating the interior button to open the trunk. Am I correct? Thank you. I am a bit of a novice at this.
GaryBHigbee
XK8
Old Jun 19, 2012 | 05:04 PM
GaryBHigbee
XK8
Gary,
Yes - that's the way.
Don't attempt to start the vehicle with this type of connection - just use it to give you power to open the trunk.
Old Jun 20, 2012 | 03:58 AM
Welcome to the forum.
Good to see you.
There you go, great advice from the guys already.
Old Jun 20, 2012 | 05:36 AM
ooootis's Avatar
That's interesting in the last 6 months TOPIx has drop the XK owners manual from the drop down list. When I was looking for info on the XK I thought for certain that it was there. Maybe not? Gray matter is starting to lose it color LOL
Update: I just took a look @ the XK FAQ's page. Man ya'll have done a bang up job. Alot more info added since I looked 6 months ago. Gary I hope you did look @ that page they even have a pic of where the connection are under the hood.
Old Jun 20, 2012 | 08:27 PM
Gary,
Thank you very much. I got the trunk open with the first attempt and apparently did no harm to my car. I hope that I can return the favor in the future.
Gary
Having the picture was great. Thank you.
Gary
Old Jun 21, 2012 | 03:23 AM
Gary,
I do like a happy ending.
Now you've got into it, this seems like a good time to get the luggage compartment keyway sorted.
Old Jun 21, 2012 | 06:08 PM
welcome aboard Jaguarforums, good to have you here with us
Nice intro too thanks for sharing.......
I see you've already had some great advice from the experts.........excellent
There's a really great mix of information, camraderrie and fun here....
Old Jun 23, 2012 | 09:43 AM
For sure.
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
Sambo21
Nov 19, 2015 03:55 PM
speacock
Sep 10, 2015 12:14 AM
al_roethlisberger
Sep 9, 2015 09:14 PM
