New 2002 X-Type 3.0L sedan owner - rear defrost problem
Old Jan 16, 2018 | 01:49 PM
vbsummers1's Avatar
Default New 2002 X-Type 3.0L sedan owner - rear defrost problem
Hi Gang,
I just purchased a 2002 x-type 4 door sedan down her in Palm City, Fl, with only 49,000 miles on it. So far, other than changing out a few things, I'm very pleased with the performance. One thing did come up, however, that has stumped me. I can't get the rear defrost to work. The front switch lights up when pressed, but there appears to be no power to the back window. I've checked all fuses and relays associated with rear defrost, but all appear to fine. Does anyone know where on the rear window the electrical attaches, or have any other ideas to check?
Old Jan 16, 2018 | 03:12 PM
o1xjr's Avatar
Welcome to the forum.
Old Jan 16, 2018 | 05:12 PM
Welcome to the forum vbsummers1,
Follow this link https://www.jaguarforums.com/forum/x-type-x400-14/ to the X-Type forum for help, advice and information.
The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the US Lower Atlantic Region forum by following this link https://www.jaguarforums.com/forum/usa-lower-atlantic-nc-sc-fl-ga-66/
Enjoy the forums.
Old Jan 16, 2018 | 06:13 PM
Old Jan 16, 2018 | 11:49 PM
Daf11e's Avatar
Welcome aboard.
Old Jan 17, 2018 | 03:11 AM
Welcome to the Forums.
Old Jan 17, 2018 | 05:50 AM
Welcome to Jaguar Forums vbsummers1,
Old Jan 18, 2018 | 07:19 AM
avern1's Avatar
The electrical connections are beneath the rear parcel shelve cover. You remove the seat belt covers and you can remove the parcel shelve and the electrical connections will be visible.
I would recommend a thorough inspection of the window for cracks or broken wire traces for the heating element.
In the engine compartment fuse 4 (30amp) controls the relay to the rear heated window. The relay is #19 in the passenger compartment fuse box beneath the dash.
It is quicker and you get more responses if you post in the X400 section of the forum. Below is a link to the X400 section of the forum.
Old Jan 18, 2018 | 07:30 AM
vbsummers1's Avatar
Wow, thanks for the quick response and direction to the right forum. Brand new to this. I really appreciate it!
Old Jan 18, 2018 | 10:30 AM
I'd go for the simplest possibility first - that the connections on the glass have been disturned during a pre-sales clean. Fuses and relays are likely to be OK if the switch is lighting up.
doesntmatter
Sep 7, 2017 09:05 PM
rob7157
Nov 24, 2014 06:26 PM
iculyn
Apr 4, 2013 08:48 PM
krash
Feb 16, 2013 06:07 PM
lamoura
Feb 6, 2013 06:48 AM
