New Jaguar guy needs help!
Old Jan 30, 2010 | 11:24 AM
robr's Avatar
Default New Jaguar guy needs help!
I had a small leak in the reservoir tank that I fixed on my '07 XJ8. Now the cooling fan runs almost all of the time. Could it be that I now have the wrong mixture of coolant to water since I have topped off the reservoir tank with water on a few occasions or maybe a bad thermostat? Any suggestions would be greatly appreciated.
Old Jan 30, 2010 | 02:35 PM
Thermo's Avatar
Veteran: Navy
robr, I would be venturing to guess that your thermostat has bound up due to the lack of coolant around it and that is causing your issues. I would recommend putting in a new thermostat and then refilling the coolant system with the proper ratio of coolant and water. It may be a good idea to do a coolant flush while you are at it to ensure you don't have any build up anywhere.
Running the coolant system low on the actual antifreeze will not cause your radiator fans to run continuously. You can run straight water and the car will run just fine. The problem comes when you get into cooler climates, if you are running pure water and the temps drop below freezing, you can crack the block really easy. Running low on actual coolant is simply raising the point at which the water/coolant mixture could freeze. But, unless you are down around 10% coolant, you don't have much to worry about unless you live in Alaska. Then, you should know better.
Old Jan 30, 2010 | 04:26 PM
Riski's Avatar
Welcome......
Old Jan 30, 2010 | 05:32 PM
robr's Avatar
Thank you for the advice. I will follow your suggestion first thing in the morning.
Old Jan 31, 2010 | 03:36 AM
Cadillac's Avatar
Welcome and keep us updated .
BTW, this forum is generally for new members who like to say "hello" .You should post your questions X Type Forum or General Tech Help so that you get quicker responses
Old Jan 31, 2010 | 05:31 AM
Welcome Rob you'll get more hits over in the XJ8 section.
Old Jan 31, 2010 | 12:48 PM
robr's Avatar
Thanks to everyone for the responses.
Old Jan 31, 2010 | 01:44 PM
Jamey's Avatar
Howdy robr
Welcome to the forum!
fast40driver
Apr 19, 2024 07:24 AM
bhojav
Sep 5, 2015 01:19 PM
wwac
Sep 1, 2015 05:45 AM
1964Daimler
Aug 31, 2015 06:41 AM
Bcrary3
Aug 28, 2015 10:13 PM
