New member, having injector problems / 1991 XJS 5.3 V12
Old Jul 14, 2018 | 03:17 PM
Harold Gibson's Avatar
Exclamation New member, having injector problems / 1991 XJS 5.3 V12
I am having problems that no one can seam to pinpoint with a 1991 XJS 5.3 V12 marelli ignition.. Have 39psi fuel pressure / have fire to both coils, distributor, all the plugs, and all injectors on the B left bank. There is 12 volts to the A right bank but no injector is firing. All of the left bank (B) are firing. Will try to start if you spray starting fluid to the right bank. Have changed both ECU. Changed the power resistor. swap the marelli amplifiers. I am thinking it is in the wiring harness. Sure would like some input. Thanks Harold
Old Jul 14, 2018 | 04:23 PM
Doug's Avatar
Failures of the injector harness are common; to the extent that many replace the harness on general principles before an actual symptom ever appears. I wouldn't be surprised if replacing it fixed your problem....especially in light of the other work done which narrows down the alternatives.. Many owners build their own harness but new ones are out there.
Old Jul 14, 2018 | 05:00 PM
Thanks Doug I think it is in the harness, although it was running 4 or 5 months ago. There was a fellow on the forum that went by Safari that said he might start building them.
Old Jul 14, 2018 | 05:29 PM
Daf11e's Avatar
Welcome aboard Harold.
Old Jul 14, 2018 | 06:03 PM
Thanks Jim, Glad to be here
Old Jul 15, 2018 | 04:00 AM
Welcome.
I agree with Doug, and my experience with these bests.
Do that harness, and then tick it off the list of culprits.
BUT
Find the EFI loom plug, usually near the A Bank camcover front edge, unplug it, and replug it, sometimes +, sometimes not.
Do the same with the resistor pack plug, and this sucker is inside the engine bay, on the inner guard, just aft of the RH headlamp binnacle.
The XJS Tech Section will have answers/ suggestions flowing much quicker than from here, so worth a repost.
Good luck.
Old Jul 15, 2018 | 05:54 AM
Old Jul 15, 2018 | 06:18 AM
Welcome to the forum Harold,
I think Doug and Grant have nailed the most likely causes. Follow this link XJ XJ8 / XJR ( X308 ) - Jaguar Forums - Jaguar Enthusiasts Forum to the XJS forum for help, advice and information.
The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the US Lower Atlantic Region forum by following this link https://www.jaguarforums.com/forum/usa-lower-atlantic-nc-sc-fl-ga-66/
Enjoy the forums.
Old Jul 15, 2018 | 08:59 AM
Welcome to Jaguar Forums Harold,
Old Jul 16, 2018 | 03:35 AM
o1xjr's Avatar
Welcome to the forums.
CW2000XJ8L
May 30, 2017 01:12 AM
jag time
Apr 7, 2011 08:14 PM
sbobev
Jul 22, 2010 06:22 PM
loaks111
Jul 10, 2008 10:18 AM
