Nsw to forum
Old Jul 19, 2018 | 09:53 AM
Freedomgwr's Avatar
Default Nsw to forum
Hello everyone, I'm George from Georgia. Just got a 1996 xj6. Had power steering leak high pressure line. I replaced it alsobreturn line. After I bleed air from system turning wheel with tires off ground manually. I drive it then when i shut car off from back pressure fluid excapes from resavoir way too much pressure. Any advice please.
Old Jul 19, 2018 | 10:39 AM
Welcome to the forum George,
Did you overfill the reservoir? Here's the bleed procedure from the Workshop Manual:
10.3.3 System Bleed (following maintenance)
To avoid fluid aeration and possible pump damage, the initial fill process must be carried out with the ignition OFF.
Set the fluid level approximately 20 mm above the upper dipstick level, and cycle the steering no less than three (3) times from lock to lock (this may be best achieved with the front wheels off the ground). As air is expelled the fluid level will fall, the level should be corrected. Start the engine and further cycle the steering until the fluid level becomes stable. Stop the engine and finally set the level in accordance with the fluid level check procedure.
Follow this link https://www.jaguarforums.com/forum/xj-xj6-xjr6-x300-26/ to the X300 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the US Lower Atlantic Region forum by following this link https://www.jaguarforums.com/forum/usa-lower-atlantic-nc-sc-fl-ga-66/ to find other members in your region.
Enjoy the forums.
Old Jul 19, 2018 | 04:24 PM
Daf11e's Avatar
Welcome aboard George.
Old Jul 20, 2018 | 05:27 AM
Welcome to Jaguar Forums George,
Old Jul 20, 2018 | 05:53 AM
o1xjr's Avatar
Welcome to the forums.
Old Jul 20, 2018 | 05:56 AM
Welcome to the Forums.
Old Jul 20, 2018 | 07:03 AM
Old Jul 20, 2018 | 03:40 PM
Hello, George,
I hope you got your power steering straightened out.
Old Jul 28, 2018 | 02:03 AM
Freedomgwr's Avatar
Default Thanks everyone
Almost their.😀😀
Stypemike
Nov 8, 2016 06:19 AM
Cambo
37
Jun 27, 2014 04:09 AM
dcburton78
Nov 20, 2013 02:38 AM
Russell11
Sep 20, 2013 06:21 AM
dstary
Apr 24, 2013 08:02 AM
