retrricted performance light
Old Apr 11, 2008 | 05:15 PM
stephen garrett's Avatar
Default retrricted performance light
Hi may i first introduce myself,
my name is stephen garrett. I am currently experiencing a problem with check engine light which stays on. And a retricted performance performance light that stays on for about a minute or so. My fault code reader reads both banks running lean. I have had the manifold, fuel fillter, and air blead hoses /air fillter replaced. Someone has also mentioned changinng lambda sensors ? . Could anyone advise me of the location of said sensors ? and any other ideas would be gratefully recived.
with thanks
stephen
Old Apr 11, 2008 | 05:48 PM
JagtechOhio's Avatar
Default RE: retrricted performance light
Hi Stephen,
You'll probably get some good help here, but you'll first have to post your vehicle model and year, and engine type. It would also be an asset to provide the Diagnotic Trouble Codes you retrieved.
Old Apr 11, 2008 | 06:15 PM
The lack of imformation I have supplied just proves my frustration. MY car is a xk8 4.00 L 2000 model. THe fault coders are p0171 bank 1 generic system to lean. p0174 bank 2 generic system to lean. thjanks for your quick responce.
Old Apr 11, 2008 | 06:20 PM
Air intake duct to throttle body split at bellows, broken full load breather pipe to A bank cam cover, loose clamp at MAFS connection to duct hose, broken part load breather pipe, remove and clean Mass Air Flow Sensor with CRC MAFS cleaner. That's where to start.
Old Apr 11, 2008 | 09:17 PM
FactoryJaguarTech's Avatar
And do not do anything with the O2 sensors. Those codes are not llikely to be cause by those.
Check all of the things Ohio mentioned.
Old Apr 12, 2008 | 04:09 AM
thanks for advice. I have air intake duct on order. Will try that first and let you know results.
Old Apr 14, 2008 | 06:25 PM
still wating to recive air input duct. but have been wondering. could this problem be a electrical fault ? as i have been treating my car with kit gloves for the last few days. and the only time the light has come on .Has been when i have been passing electric pylons.
Old May 2, 2008 | 05:06 PM
Hi friends,
A note of premeture thanks. Recived throtle body duct and changed with no results. Checked clamps and connections with no change. Decideded to take full bellows apart. Cleaned the lot with carb cleaner. redone connections and scrubed throtle body with carb cleaner and bingo ( i think). not counting chicken s yet but have been well fed off there eggs.
Thanks again will be glued to these pages.
steve
Old May 2, 2008 | 05:12 PM
P .S. forgot to mention. Cleared fault codes, and recived a alien one. P111 jaguar system pass. Whilst i expect a bit of turmoil with a jag. I hope this is a end to this problem.
Thanks again
Steve
aholbro1
Dec 29, 2024 06:46 PM
D.K
Dec 10, 2023 02:05 AM
Jpav27
Jul 31, 2022 06:43 AM
scottatl
Sep 4, 2015 08:08 PM
XFR_Gold
Sep 2, 2015 12:24 PM
