Engine Overheating
Old Oct 11, 2011 | 10:39 PM
mshrull9988's Avatar
Default Engine Overheating
I had a coolant leak and determined that the reservoir was cracked. After replacing suddenly my engine started getting warmer than normal, but not by a lot. although 3 days my radiator blew. The leak must've been allowing pressure to release but what i cant figure out is why the pressure is building so high to begin with and what would be causing the sudden overheating. Does anyone have any thoughts on the matter. I'm replacing the radiator on thursday but would like to know what else i should be looking at or replacing.
Old Oct 11, 2011 | 10:43 PM
Information on proper remove and replace of radiator would be greatly appreciated as well.
Old Oct 12, 2011 | 04:39 AM
JagV8's Avatar
Maybe there was/is an airlock?
Old Oct 12, 2011 | 10:02 PM
after letting it sit for a couple days, i wanted to take a closer look at it to really see the damage and was baffled by the fact that suddenly my reservoir is now full. when i parked it, it was empty. Any ideas on that one?
@jagv8 that is a viable option but i dont know how i would fix that. would a system flush fix that?
Old Oct 13, 2011 | 02:04 AM
JagV8's Avatar
Doesn't sound like an airlock after all. I'm baffled. (When I park the level in mine drops very slowly, but not far, as the engine cools.)
Old Oct 13, 2011 | 02:34 AM
i hate to change the radiator without knowing the contributing cause. right now i'm just hoping that a complete system flush will do it.
Old Oct 13, 2011 | 05:39 AM
JagV8's Avatar
With such unusual problems (rad hardly ever fails, etc) you might like to have a pro check for head gasket problem.
Old Oct 13, 2011 | 08:00 PM
thanks jagv8, i will probably end up having a mechanic look at it but am trying to save a little cash and diagnose it myself. I'll post an update after i change the rad. and do a flush.
cissdm
May 3, 2016 06:02 AM
Raul Lara
Sep 14, 2015 07:31 PM
alpecsa
Sep 7, 2015 11:55 AM
Bcrary3
Sep 3, 2015 03:48 PM
Raul Lara
Sep 2, 2015 05:23 PM
