Master window switch good but not working, bad module?
Old Dec 1, 2012 | 04:46 PM
03Xtype's Avatar
Default Master window switch good but not working, bad module?
On my 2005 s type the driver door switch will lower but not raise the passenger window. I hooked this switch up to my STR and it worked normaly. So I guess I'm dealing with a bad module? Could a reprogram help? If I take a module off my 03 STR will it plug in and work in order to help diagnose?
Old Dec 2, 2012 | 08:44 AM
JagV8's Avatar
Wiring may be more likely.
Old Dec 3, 2012 | 02:59 PM
03Xtype's Avatar
Is there a common area for wiring issues, maybe the wire loom between the door and body of the car?
I swapped the DDM with one I know is good and had no change, assuming the ddm controls the master window switch.
Old Dec 3, 2012 | 05:38 PM
joycesjag's Avatar
There have been 1 or 2 members over the years that had pinched wires between the door and the body.
Old Dec 3, 2012 | 10:34 PM
Brutal's Avatar
try rebooting the battery first
Old Dec 3, 2012 | 10:39 PM
03Xtype's Avatar
I had the batt disconnected for about 45min. No related codes on the SDD.
Old Dec 4, 2012 | 09:50 PM
03Xtype's Avatar
The wire diagram shows the DDM has nothing to do with the window up/down switch wires, I'll start probing wires this weekend.
Old Dec 6, 2012 | 08:40 PM
03Xtype's Avatar
As this wire harness enters in to the body of the car I cant seem to find any access points to probe the GW wire. Any tips? It looks like the harness runs in between the layers of the unibody.
Old Dec 8, 2012 | 11:55 PM
03Xtype's Avatar
Found and fixed my broken wire on the driver door loom that runs in between the door and body.
Attached Thumbnails Master window switch good but not working, bad module?-pc080063.jpg   Master window switch good but not working, bad module?-pc080064.jpg
Old Dec 9, 2012 | 02:02 AM
Thanks for that, looks like real easy to at, haha.
Maybe that is why the mirrors on ours are "dead", mmmmm.
BrentGardner
29
Dec 16, 2024 12:13 AM
kenatofc
Oct 27, 2015 06:48 AM
johnnie ryall
Oct 19, 2015 09:44 PM
Jandreu
Aug 29, 2015 07:31 PM
Terrance Williams
Aug 26, 2015 11:50 AM
