03 jaguar s-type-r restricted proformance light on
Old Jan 16, 2014 | 10:12 AM
xxzucoxx's Avatar
Default 03 jaguar s-type-r restricted proformance light on
I have a 2003 jaguar s-type -r 4.2 supercharged with 110k miles, I have replaced the valve cover gaskets, with the spark plug tubes, I have put new spark plugs in they where 11$ a spark plug, I have bought 8 brand new coils, installed them, and the car keeps missing when its cold it will not even move when stated cold it shakes and turns off, after the car is a little warmed up it will run just fine, I do have two bad 02 sensors I have but have not installed them, do you guys know what the problem could be , I do run premium gas in it.
Old Jan 16, 2014 | 10:15 AM
xxzucoxx's Avatar
po300
po301 cylinder1
po302 cylinder2
po303 cylinder3
po304 cylinder4
po305 cylinder5
po306 cylinder6
po307 cylinder7
po308 cylinder8
p1313
p1314
p1316
po037
p1647
p1000
Old Jan 16, 2014 | 11:09 AM
JagV8's Avatar
Were they the correct plugs, coils and if fitted O2s?
I think you have the worst set of codes I've seen in 5 years. Something is very very wrong.
Old Jan 16, 2014 | 11:32 AM
xxzucoxx's Avatar
as far as I know everything is correct but the car runs so smooth after it runs for 3 minutes
Old Jan 16, 2014 | 12:33 PM
xxzucoxx's Avatar
NGK IX Iridium plugs
Old Jan 16, 2014 | 12:58 PM
JagV8's Avatar
Don't sound right. Should be IFR5N10. Yours may be OK for all I know, though. I guess the gap size would matter...
Old Jan 16, 2014 | 01:38 PM
xxzucoxx's Avatar
NGK IX Iridium/Spark Plug (5464) | AutoZone.com
Old Jan 16, 2014 | 02:25 PM
xxzucoxx's Avatar
it could be a coolant temp sensor
Old Jan 16, 2014 | 04:04 PM
tbird6's Avatar
Sounds like a connection problem? With all 8 cylinders giving codes you need to look at things that are common to all cylinders. Like the fuel injection harness. Take the plugs apart and reseat them. Also check the grounds and clean and re-tighten them.
Are you clearing the codes after you read them? You have so many that you need to start over from scratch.
Old Jan 16, 2014 | 06:22 PM
tony1963's Avatar
You need to be SURE that the spark plugs have the right gap. They will be very small since the supercharged engine, like a turbo engine, can't run with large gaps. The increased pressure in the cylinders suppresses the spark.
Stop using fancy plugs.
BrentGardner
29
Dec 16, 2024 12:13 AM
lee,lee
Aug 31, 2015 04:35 PM
tonydbaker
Aug 30, 2015 11:02 PM
gene1
Aug 27, 2015 08:56 PM
Terrance Williams
Aug 26, 2015 11:50 AM
