06 STR Stumbles at idle soon after cold start
just finished replacing infamous heater hose and replaced at the same time:
fuel injectors,
plugs
all gaskets down to heads
knock sensors
vacuum lines/o-rings
fuel filter
supercharger pump
cleaned connector corrosion
power steering hose to cooler
RCCM
supercharger oil
supercharger pulley
reset the adaptations and the modules using v130.03 SDD
Car runs great b ut immediately after starting the idle quality goes to **** for maybe 15 secvonds then clears up and idles fine.
Any ideas? I will try and get a video
fuel injectors,
plugs
knock sensors
fuel filter
supercharger pump
RCCM
supercharger oil
supercharger pulley
How much have you driven the car since resetting the adaptations? I thought it typically took several days for the computer to properly relearn everything.
Give it a chance for trims to settle - don't clear anything or disconnect the battery.
Get engine hot then park.
See what LTFTs & STFTs are (at idle).
If it's relearned, STFTs should be near zero.
In case any LTFT is not within (say) 5 of zero, rev to 2500 and see what the LTFTs are.
Ok so after a day of driving it seems to have cleared up Thanks all! No more stumble.
I do have a MIL lit so I will check that and ny STFT and LTFT when I get home tonight.
Oh and the divers side low beam headlight stopped working today. Thought I fixed it but it went out as I was adjusting it. I will make a new post
Bmwm5lover
38
Jan 25, 2017 11:45 AM
hollywooddippa
Jul 27, 2012 12:14 PM
