06 STR Stumbles at idle soon after cold start
Old Aug 25, 2019 | 10:16 AM
Aarcuda's Avatar
Default 06 STR Stumbles at idle soon after cold start
just finished replacing infamous heater hose and replaced at the same time:
fuel injectors,
plugs
all gaskets down to heads
knock sensors
vacuum lines/o-rings
fuel filter
supercharger pump
cleaned connector corrosion
power steering hose to cooler
RCCM
supercharger oil
supercharger pulley
reset the adaptations and the modules using v130.03 SDD
Car runs great b ut immediately after starting the idle quality goes to **** for maybe 15 secvonds then clears up and idles fine.
Any ideas? I will try and get a video
Old Aug 25, 2019 | 12:09 PM
kr98664's Avatar
Car runs great but immediately after starting the idle quality goes to *poo-poo* for maybe 15 seconds then clears up and idles fine.
How much have you driven the car since resetting the adaptations? I thought it typically took several days for the computer to properly relearn everything.
Old Aug 25, 2019 | 01:19 PM
JagV8's Avatar
Give it a chance for trims to settle - don't clear anything or disconnect the battery.
Get engine hot then park.
See what LTFTs & STFTs are (at idle).
If it's relearned, STFTs should be near zero.
In case any LTFT is not within (say) 5 of zero, rev to 2500 and see what the LTFTs are.
Old Aug 25, 2019 | 02:17 PM
abonano's Avatar
As everyone has said give the PCM and associated modules to "learn", typically 50 to 150 miles of assorted driving. (City/Highway)
If you cleared adaptations on TCM avoid sports mode.
Old Aug 26, 2019 | 08:28 AM
Aarcuda's Avatar
Ok so after a day of driving it seems to have cleared up Thanks all! No more stumble.
I do have a MIL lit so I will check that and ny STFT and LTFT when I get home tonight.
Oh and the divers side low beam headlight stopped working today. Thought I fixed it but it went out as I was adjusting it. I will make a new post
Bmwm5lover
38
Jan 25, 2017 11:45 AM
bostongrun
Feb 10, 2014 10:06 AM
bostongrun
Dec 26, 2013 12:29 PM
bostongrun
Dec 16, 2013 01:09 PM
hollywooddippa
Jul 27, 2012 12:14 PM
