2000 S-Type 3.0 Takes Several Key Turns to Start
Old Apr 25, 2020 | 12:34 PM
snooktarpon's Avatar
Default 2000 S-Type 3.0 Takes Several Key Turns to Start
About 2 weeks ago, my 2000 S-Type 3.0 starting having some issues starting. When I insert the key, it starts to beep. I turn the key, the seat moves to the memorized position. Then when I turn the key further to start, about 3 out of 4 times, nothing happens. On the 4th time, it starts up just fine. Any clue on what is happening and how to fix it?
Old Apr 25, 2020 | 01:38 PM
NBCat's Avatar
How many kilometres/miles are on the vehicle? Are there any DTCs stored in the system?
It could be a relay, the ignition switch or a wiring loom issue.
Old Apr 25, 2020 | 04:11 PM
motorcarman's Avatar
The next time it won't start just turn the key to ON and watch the PATS light to see if it will blink a 'CODE'.
worth a try?
Old May 25, 2020 | 12:42 PM
When I turned turned the key and it wouldn't, the PATS light would flash continuously. So I was wondering if it's a PATS issue based on the previous post.
I then swapped the key (I have two keys), and I have NOT had an starting issue with the 2nd key.
So I do resolve the starting issue with the 1st key?
Old May 25, 2020 | 08:55 PM
The PATS light will flash continuously for 60 seconds and THEN flash a 2 digit code.
bob
Old Jun 9, 2020 | 01:57 PM
wydopnthrtl's Avatar
If its not those... I've seen plugged fuel filters give similar symptoms. (multiple times and on different makes of cars)
RBSJAG85
Jul 31, 2017 10:14 AM
jagthomson
Dec 3, 2014 08:40 AM
geberhardt
Sep 24, 2014 01:10 PM
GaryBKirk
Jun 3, 2013 04:22 PM
pmalla5
Feb 4, 2009 09:29 PM
