2000 s type 3.0 would not turn over?
Old May 24, 2015 | 09:12 PM
nelsonht's Avatar
Question 2000 s type 3.0 would not turn over?
Hi again, Check this out. My 2000 s type 3.0 with 72000 miles would not turn over this am. All lights and other electrical ok. After several attempts with no luck I noticed the hand brake was pulled up tight, and released the hand brake and my baby started with no problems the rest of the day. I read in the forums that its good to set the hand brake to stop movement of car prior to shifting into park so the shifter wont lock up. Has this happened to anyone as I cannot find in other posts. I would like to nip it before it causes problems. Love my S Type
Old May 24, 2015 | 10:26 PM
davidladewig's Avatar
you pull and release the parking brake and the car starts? Sounds like a loose connection or a ground fault from chafing. I would get that car up high on a rack and start looking.
Old May 25, 2015 | 09:24 AM
Mikey's Avatar
Possibly the transmission was not fully in the park position.
Old May 25, 2015 | 10:10 AM
NBCat's Avatar
Check the shift cable to the gearbox as the two bolts can have a tendency to loosen and cause the vehicle to not be in the park position when trying to start the engine.
Old May 25, 2015 | 04:57 PM
nelsonht's Avatar
Default jag would not start
Thanks David, Found problem with not quite in park.
Old May 25, 2015 | 05:01 PM
nelsonht's Avatar
Thumbs up
Thanks Mikey. You got it right.NOT FULLY IN THE PARK POSITION. Sometimes you cant see the trees thru the forest. Will double check the contacts. Thanks again. Nelson123
Old May 25, 2015 | 05:08 PM
nelsonht's Avatar
Thanks NBCat. Was not fully in park. Moved the shifter and bingo, started. Guess I didnt get enought sleep last night. By the way, exactly where are the two bolts located. I read this in one of the posts but not sure if in the top with the shifter or under the car.Thanks again. Nelson123
Old May 26, 2015 | 01:57 AM
NBCat's Avatar
The bolts for the shift cable are underneath the vehicle.
Old May 27, 2015 | 05:02 PM
nelsonht's Avatar
THANKS NBCat. I will check tomorrow and tighten. Jags running great and will keep on top of these small problems before they get out of hand.
MJ'S Jag
Nov 10, 2022 08:14 AM
tonimccloud
Sep 3, 2015 07:58 PM
Rusty1952
Sep 1, 2015 05:45 AM
nelsonht
Aug 30, 2015 06:01 AM
EastFalk
Aug 29, 2015 08:22 PM
