2000 s-type fuel pump works sometime
Old Sep 26, 2017 | 04:21 PM
hill's Avatar
Default 2000 s-type fuel pump works sometime
2000 jag s-type. When i go to start the car there is no fuel pump. I turn the key off 1 time some times it takes 2 times then the pump will come on and start right up. I have replaced the pump and swapped the relays
any help would be grate
Old Sep 26, 2017 | 05:18 PM
kr98664's Avatar
Take a look at the sockets where the relays plug in. In a couple of recent threads, people have found loose sockets and been able to pry the contacts out slightly to reestablish a good connection.
You could even make a test gauge from a strip of thin metal the same thickness as the socket prongs. Slip the test gauge into each socket to find any that don't have enough tension.
Old Sep 26, 2017 | 05:24 PM
hill's Avatar
i will check that now
Old Sep 26, 2017 | 05:45 PM
hill's Avatar
Everthing there feels nice an tight
Old Sep 26, 2017 | 06:31 PM
hill's Avatar
I now know that the prob in its the security system if i trun the key on an no pump i can leave the key on the the security light will start flashing if the pump comes on the security light will go out. Now i have to figer out why
Old Sep 26, 2017 | 09:46 PM
kr98664's Avatar
Good troubleshooting, although it's okay to use punctuation. Unlike Twitter, there's no character limit here...
Now the trick is to figure out what input is causing the security lockout. I'm not well versed with the system.
By the way, thanks for humoring me and checking the relay sockets, even though that wasn't it.
Old Sep 27, 2017 | 05:12 AM
kr98664's Avatar
Do you have a spare key you can try?
Old Sep 27, 2017 | 10:36 AM
hill's Avatar
i do not have a spare key i only have 1 an 1 remote. I dont even have the green key.
Old Sep 28, 2017 | 02:05 PM
clubairth1's Avatar
Community Influencer
When the PATS (red light on dash) is flashing. Try to count the flashes. They usually will be repeated so just keep counting and writing it down until you kind of get the rhythm down. The longer pauses separate one sequence from another. Sort of like Morse Code.
Sometimes it just flashes real fast and is not indicating a code.
Might give another clue?
Old Sep 28, 2017 | 03:36 PM
hill's Avatar
its giving me code 16
Old Sep 28, 2017 | 04:48 PM
NBCat's Avatar
How old is the battery? A failing or weak battery can cause many mysterious electrical faults.
Old Sep 28, 2017 | 10:46 PM
hill's Avatar
The battery is only about 8 moths old. It checked good.
Old Sep 29, 2017 | 01:30 AM
JagV8's Avatar
Already answered by Bob https://www.jaguarforums.com/forum/s...3/#post1766938
Old Oct 17, 2017 | 05:03 PM
hill's Avatar
Ok so i took the car to the dealership over two weeks ago and they said it needed a new key an $800 to fix(after the car had been there 2weeks). Took 4 days for them to get the new key. They texed me today and said the key was in and that it should be ready today. As i was getting ready to make the hour an a hafe trip there they texed me an said the car still will not start and that the ECM is offline. If that is the case they should have know that as soon as they hooked up the the scan tool.I have been working on cars all my life from small shops to dealership and that is something you know real quick!
Old Oct 21, 2017 | 12:45 PM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Get them to commit all this to a wriiten explanation of the problem and their proposed solution / estimate. Sounds like you are about to do battle with the dealership.
My own personal experience with a dealership technician & service writer was horrible and I exposed a scam they were doing to unsuspecting customers. My lesson learned was ALWAYS involve the Service Manager if you have any doubts that you are being sold unnecessary services / parts you don’t need and PRAY that Svc Mgr makes it right. But always start with WRITTEN documentation.
