2000 S Type Hood Mat
Old Dec 18, 2014 | 01:40 PM
Dudes08's Avatar
Default 2000 S Type Hood Mat
Just purchased this 08 S Type and found the hood mat in the trunk. A test fit showed that is has shrunk and the holes no longer line up. I can get push retainers in the center three holes then glue (temporary) the rest of it in spots. However, I prefer to replace it. Found a few on line in the $230.00 range. Does anyone know where to purchase a good quality mat that fits.
Old Dec 18, 2014 | 10:02 PM
Dennis Catone's Avatar
I have been looking for a hood insulation mat with no luck at all so if you find a good source please post it.
Old Dec 19, 2014 | 02:11 AM
bydand's Avatar
Default Under bonnet sound/heat insulation
+1 on that.
Mine has also appeared shrunk, and pulling on all the securing screws.
Looking for the 4.2ltr insulation.
Anyone have thoughts as to why this is happening?
Overheating at sometime, or age related??
Old Dec 19, 2014 | 04:02 AM
JagV8's Avatar
Someone was making them! Anyone recall who? Details were posted but an age ago.
Old Dec 19, 2014 | 04:33 AM
bydand's Avatar
Default God Bless Mice!
Originally Posted by bydand
+1 on that.
https://www.jaguarforums.com/forum/x...acement-30938/
Well a starter for someone, have to read through it now and see if they are still going.
Sadly not, RIP Gonzo
https://www.jaguarforums.com/forum/m...rs-net-121206/
some useful info on the web page, check it out.
Old Dec 19, 2014 | 06:00 AM
joycesjag's Avatar
I did not read the links. Although Gonzo has passed, I thought that a friend was going to take over Gonzos business.
Has anyone tried Gonzos old contact info.?
Old Dec 19, 2014 | 11:39 AM
Dudes08's Avatar
I found one supplier for $291.57. Here is the link: Jaguar Hood Pad, XJ6, XJ8, XJS, XK8, S-TYPE, X-TYPE, XJ40, X300, X308, jaguar parts
Old Jan 20, 2015 | 05:43 PM
bydand's Avatar
Default Under hood insulation material Closed-cell vinyl nitrile
SSP Foam Mat 1/4 thick by 48 wide (per foot)-Super Soundproofing Store
SSP Foam Mat 1/4" thick by 48" wide, weight per foot = 0.15 sqft. / 0.6 lf.
Super Soundproofing Foam Mat for noise control: A closed cell vinyl-nitrile noise control FOAM suitable as a sound barrier as well as a sound absorber. For application to cars, boats, planes, home and office, anywhere a noise control mat is needed. Won't absorb moisture or odor, long lasting and durable. An excellent soundproofer and thermal insulator! (FAA Approved for aircraft, too! Ask for the lab burn tests that others can't supply!). Just apply with our PSA (Pressure Sensitive Adhesive- peel-off backing) or contact cement to reduce and absorb sound. (Note: this is NOT the cheap crappy rubber/neoprene as sold by some of our competitors said to defeat ambient noise!) Stock# 09-42720
This would appear to be the material Gonzo was using for his hood linings material.
Just need to find a supplier, locally or one that ships internationally.
This is just for the material, not precut for fitting. You would have to do the DIY to fit it yourself, and glue it on.
Last edited by bydand; Jan 20, 2015 at 05:47 PM. Reason: Note just the material, not cut to shape etc.
Old Jan 20, 2015 | 09:55 PM
Warspite's Avatar
Any chance of scoring a good used one, like on Craigslist? So many part outs with mint body panels...when drivetrains bit the dust.
Sprayall
May 30, 2021 08:13 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Sprayall
Sep 3, 2015 07:49 PM
dcvickers
Sep 2, 2015 06:14 PM
nelsonht
Aug 30, 2015 06:01 AM
