2003 S-Type 4.2 V8 Tie Rod Replacement
Old Nov 26, 2018 | 10:49 AM
Seth Johnston's Avatar
Default 2003 S-Type 4.2 V8 Tie Rod Replacement
So I am in need of replacing an inner tie to rod on my 03 S-Type, and am wondering about a rough estimate, and if it would be worth it just to fix it my self. Also if any of you have a clue as to how much work it would be to fix it myself, I'll take all the advice I can get.
Old Nov 26, 2018 | 01:28 PM
joycesjag's Avatar
Save money do it yourself. Purchase parts from a forum sponsor. Download workshop manual free here.
Old Nov 27, 2018 | 05:15 PM
scottjh9's Avatar
If you do it.... make a careful measurent of the old tie rod length or count the threads showing and you won't have to get an immediate alignment. If you measure.... do it from where the tie rod threads in.... to the outer edge of the pivot end either before or after you pop it off the taper
Old Nov 28, 2018 | 02:43 AM
wydopnthrtl's Avatar
I did my own rear tie rods. Its easy but you'll need to check alignment afterwards.
https://www.jaguarforums.com/forum/s...e-rods-209024/
Old Nov 29, 2018 | 10:03 AM
JagV8's Avatar
I measured mine very carefully and set the new ones to the same values - the alignment when checked was spot on
This way even if a little out you'll not wear the tyres much until the alignment is checked/adjusted.
Old Nov 29, 2018 | 10:23 AM
scottjh9's Avatar
Exactly..I use a digital dial caliper to measure thread length. A lot easier than counting threads with iffy eyes
joycesjag
54
Jan 29, 2025 09:33 AM
benpearce2013
Feb 13, 2017 09:29 AM
SamOscarBrown
Nov 4, 2013 08:16 PM
Amadauss
48
Jul 28, 2012 07:41 PM
GordoCatCar
May 8, 2008 12:47 PM
