2003 S-type 4.2L crankshaft pulley removal
Old Feb 19, 2021 | 11:59 PM
Chidestp's Avatar
Default 2003 S-type 4.2L crankshaft pulley removal
Question: has anyone else had trouble removing the crankshaft pulley to get to the timing cover? I got the crankshaft pulley bolt out already. I know there is special tool (puller) for this but can’t a regular metric puller work just as well. Is there a washer in the crankshaft bolt hole that is binding the pulley when the puller is engaged? Is is necessary to use the Jaguar approved puller to remove the pulley? I attached am look inside the crankshaft pulley bolt hole.
Old Feb 20, 2021 | 08:18 AM
motorcarman's Avatar
Same procedure for the last 2 plus decades.
File Type: pdf
Old Feb 20, 2021 | 11:41 AM
Chidestp's Avatar
Thanks... is the XK crank damper different from S type? I don’t see the cylindrical split cone on the S type
Old Feb 20, 2021 | 12:54 PM
JEPC shows ALL V8 S-Types have #4 SPLIT COLLET (damper to crankshaft) AJ89854
Old Feb 20, 2021 | 02:18 PM
Chidestp's Avatar
You’re right! Of course. Thank you... got it off finally by using universal puller and hitting with heavy hammer every couple of turns. Do I need to now replace the collet after removing or reuse ? Last question? Thanks for your patience!
Old Feb 20, 2021 | 04:15 PM
Chidestp's Avatar
Old Feb 20, 2021 | 08:02 PM
I re-use the collet. Jaguar make no mention of one-time-use collets.
(as per the TSB)
Note: Always replace the timing case oil seal, the damper O-ring, and the
damper retaining bolt with new items any time the damper is removed.
The bolt can be reused if the threads are OK and you use a locking compound but Jaguar advises a new bolt.(use your own judgement)
I have removed bolts that had damaged threads so I used a thread chaser in the crank and a new bolt.
Old Feb 22, 2021 | 12:08 AM
Chidestp's Avatar
Default Thanks for the sage advice
I bought a new bolt because old one had thread damage. That bolt behind the steering pump mounting bracket is a bear ... guess I should take off steering pump and mounting bracket? Will timing cover come off if the T40 bolt is removed from steering pump mounting bracket. Will be using lots of loctite eventually
Old Feb 22, 2021 | 03:50 PM
Chidestp's Avatar
Default In other words
Do any of the 5 bolts (one is a T40 bolt) that thread from the steering pump mounting bracket into the timing cover to bind it in place? Thanks!
Old Feb 22, 2021 | 03:52 PM
Chidestp's Avatar
Default In addition
I will be reusing the split collar collet because it was in great shape. A universal puller did fine in place of the Jaguar special puller tool.
Old Feb 22, 2021 | 03:53 PM
Chidestp's Avatar
I also got a new damper with a new o ring. 👍
Old Feb 22, 2021 | 09:20 PM
davidladewig's Avatar
(as per the TSB)
A few years ago, you talked about a correct puller. I bought one and taking this pulley off was easy. This is the kit I got to do this job. Thanks way too late for your tip.
Old Feb 23, 2021 | 12:55 PM
Chidestp's Avatar
Default I tried to buy the special tools
From Christopher’s Foreign Auto Parts (great people BTW) and eBay. They were on back order in Hong Kong... I couldn’t wait so I made do. Thanks!
Old Feb 23, 2021 | 12:58 PM
Chidestp's Avatar
Default Does anyone know if timing cover in held in place by steering pump bolts
I’ve got the 24 timing cover bolts out and it still seems bound
Old Feb 23, 2021 | 07:48 PM
On the 2000 4.0, the AC and Alternator had to be unbolted and moved back. Check and see if there is a lip on the AC housing or Alternator. I don't have a book on the 4.2.
Hyrum Lindquist
May 11, 2020 10:06 PM
bighoks
May 7, 2020 08:54 AM
XK for life
Jul 5, 2018 04:33 AM
nilanium
Mar 9, 2017 11:32 AM
dww
Jan 27, 2014 09:30 PM
