2003 S-Type issues with trans
Old Mar 2, 2019 | 11:08 AM
Paulantent's Avatar
Default 2003 S-Type issues with trans
Hey everyone,
I have a 2003 2-type 3.0 and it seems to be having some transmission issues. The symptoms are as follows. It give a clunk when you put the car in to drive or reverse. It also won't shift out of 1st gear. There are a few error codes from ABS and Gearbox fault. Also on the computer the codes are p0701 and p0731
Any advice?
Old Mar 2, 2019 | 11:25 AM
Welcome to the forum Paulantent.
Please post an intro in the new members section when you can.
First step is to make sure the battery is fully charged, then I'd try and trace the ABS faults first they may be upsetting the tranny.
Old Mar 2, 2019 | 11:37 AM
Paulantent's Avatar
Hey thanks for the reply.
I also needed to mention that I have a wheel bearing in the rear that has needed to be replaced. It has caused some excessive vibration on the car.
Old Mar 2, 2019 | 12:19 PM
kr98664's Avatar
+1 on that. More details on your P0701 and P0731 codes here:
http://www.jagrepair.com/images/Auto..._OBD_II_R2.pdf
Note how P0701 is related to a DSC (Dynamic Stability Control) fault. The manual says to look for related DSC fault codes. Keep in mind most scanners can't read Jaguar-specific codes, just the generic emissions codes that all newer cars use. Could be you've got a DSC fault due to the rear wheel bearing issue, but your scanner can't tell you.
Two options:
1) Replace that suspect wheel bearing and see if P0701 clears itself.
2) Take the car to a Jaguar specialist shop (dealer or independent) that has a scanner that can read all the codes, not just the generic ones.
Your call, but since you know you have to replace that wheel bearing assembly, I'd fix the known problem first. You've got to replace it anyway, so it's not wasted money if no help with the other stuff.
Old Mar 7, 2019 | 05:59 AM
Paulantent's Avatar
Norri, thank you for the reply and help! I will check the battery to make sure it is fully charged. May I ask how the ABS might affect the trans?
Old Mar 7, 2019 | 06:40 AM
Paulantent's Avatar
Default TCM replacement
Do you think a TCM module might be the issue?
Old Mar 7, 2019 | 06:48 AM
JagV8's Avatar
No.
Best bet is follow the advice already given.
Old Mar 7, 2019 | 04:01 PM
abonano's Avatar
Agreed, no
Old Mar 7, 2019 | 04:43 PM
The ABS sensor provides information to the transmission if that's info is not good the trans will get confused, the wheel bearing may be causing the ABS fault.
Do the easy stuff first.
Old Mar 7, 2019 | 06:35 PM
Paulantent's Avatar
Update, the car is now running normal! Transmission is changing gears.
More info to follow as the car is being used by one of the guys that work for me and as soon as I get the details I will post.
Thanks again for the comments and help.
Old Mar 8, 2019 | 09:59 PM
kr98664's Avatar
Well? The suspense is killing me. Tell your employee that you will dock his pay until he spills the beans.
digimurda
Feb 12, 2021 08:03 AM
Fairfalcon
Jan 28, 2018 02:04 PM
JaguarXKR
Aug 8, 2013 11:38 AM
WhiskyTangoFoxtrot
Jun 16, 2011 08:48 AM
Audie1966
Mar 3, 2011 05:03 PM
