2006 s type trunk wont open,
Old Jul 27, 2018 | 02:33 AM
raymo's Avatar
Default 2006 s type trunk wont open,
2006 s type trunk wont open, I have 2 keys but none of them turn in the key hole?????
Old Jul 27, 2018 | 02:40 AM
raymo's Avatar
Oops typo its a 2008 although dont think there is a difference!
Old Jul 27, 2018 | 03:48 AM
joycesjag's Avatar
Have you tried lubercating the keyhole?
Old Jul 27, 2018 | 04:57 AM
Busa's Avatar
A good dose of WD40 applied into the key slot with the thin plastic pipe is best but spray the key slot and push the key in and out and waggle it around.
Because they don't get used they gunk up.
Old Jul 27, 2018 | 06:31 AM
kr98664's Avatar
Perhaps you have two valet keys? They are cut slightly different so they won't open the trunk or glovebox. They only work the door and the ignition.
I think the difference is the bevel on the end, but am not positive. Anybody know for sure?
If the trunk won't open with the remote or the dash switch, check the valet button in the glovebox. If accidentally depressed (easy to do), it inhibits the electric release.
Old Jul 27, 2018 | 06:36 AM
The regular key has a smaller bevel on the end.
Old Jul 27, 2018 | 06:43 PM
scottjh9's Avatar
Right on about the valet key..i took one of mine and filed it smaller to work the trunk....that is my daughters key..at least if she loses or misplaces it i am not out the way expensive original one
Old Jul 27, 2018 | 07:27 PM
Datsports's Avatar
you can add 12v power to the power junction supplied behind the right hand front plastic under guard panel .
to boost power.
or charge the battery slowly through the eng bay fuse box.if low voltage is the primary issue .
jgpflaumer
Jul 9, 2018 11:36 PM
MeatBag
Jun 7, 2018 09:40 PM
Iscsam
Nov 8, 2017 10:41 AM
jagastruckerhoodornament
Mar 29, 2015 08:21 AM
