aircon pully change
Old Aug 30, 2012 | 05:41 AM
shejag's Avatar
Exclamation aircon pully change
Hi All
Can the aircon drive pully be changed insitu on a V6 S type , my drive pulley sounds dry but has no play.
I tried searches for anyone who has done this without success
Old Aug 30, 2012 | 07:45 AM
abonano's Avatar
Please provide vehicle info, year, engine... Please also add this information to your signature line - it would be quite helpful in order to draw proper responses to your inquiry.
Old Aug 30, 2012 | 12:33 PM
tbird6's Avatar
You can change the magnetic clutch but I don't know what a dry pulley sounds like??
Bearings will make a noise but you change that with the clutch so I would not change anything until I was sure.
Have you removed the belt to verify where the noise is coming from??
Have you chnaged the belt as that is always a good first step.
Old Aug 30, 2012 | 02:13 PM
shejag's Avatar
Hi
I have had the belt off and rotating the pully sounds a little noisy I think I could remove the circlip but there is no room for a bearing pully to pull of the pully. The JTIS states that the pully should br a slip fit? I hoped someone has carried this out before and could tell me it is possible
The car is 2.5 V6 2005 S type
John H
Old Aug 30, 2012 | 03:19 PM
https://www.jaguarforums.com/forum/x...59/#post366628
Take a look at post #5 it might help you.
Old Aug 30, 2012 | 06:58 PM
Brutal's Avatar
Yes you can but youll need a shim kit to set the correct gap. And you have to remove the comressor to do it. With all the work why not wait till it fails, if ever?
Old Aug 30, 2012 | 08:04 PM
joycesjag's Avatar
Man norri you pulled through agian!
What a great post
Old Aug 31, 2012 | 06:13 AM
You made me hunt for it Rick, I thought it was in the S section.
Old Sep 1, 2012 | 06:07 AM
shejag's Avatar
Hi all
After some further investigations I have found that the clutch coil is overheating (ie drawing overcurrent) this has damaged the bearing seals the neoprene seal has disintergrated and turned brittle. this also has destryed the clutch plate torque rubbers. Although the clutch is still operating it is overheating, I suspect short circuit turns in the clutch coil
So its a new complete clutch and coil if available or a new compressor complete.
So is it possible to purchase a new clutch and replace in situ
John H
Old Sep 1, 2012 | 10:23 AM
Panthro's Avatar
Would it be easier to replace the compressor?
Old Sep 1, 2012 | 10:33 AM
I'd be thinking that way, don't forget ebay.
Old Sep 1, 2012 | 11:57 AM
carelm's Avatar
You may also want to try car-part.com although they may be stateside only.
Jandreu
Jun 30, 2022 03:10 PM
Scarecrow
Mar 28, 2016 03:17 AM
roby
Sep 20, 2015 01:54 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Gerard Radimaker
Sep 13, 2015 10:33 AM
