another damn code p0171
Old Dec 19, 2015 | 03:40 PM
anthawk's Avatar
Default another damn code p0171
Not even a month since I sorted the coil problem when another problem has come up was driving today put my foot down and a restricted performance came up for about one minute once it went the car drove ok stopped at traffic lights put my foot down to move off message again ran a scan which came up with system too lean bank 1 checked fuel trims this is what I got
at idle bank1 short term 25% long term 19.5 bank 2 short term 25% longterm 19.5 with the throttle held at 2k rpm readings were bank1 short term21.9% longterm 47% bank2 short term 18.8% long term 0% any ideas
Old Dec 20, 2015 | 07:21 PM
ZenFly's Avatar
A vacuum leak perhaps?
Old Dec 21, 2015 | 10:59 AM
anthawk's Avatar
well yesterday I went to have a look at my air flow meter and noticed the pvc hose was completly disconnected from the intake pipe I think it might have been loose and my arm may have brushed against it completly disconnecting it as before the restricted performance message was intermittent but then the message was there all the time I reconnected it and cleared the codes the message has not come back and no mil light only time will tell as my mileage is pretty low as I have a company vehicle
Old Dec 21, 2015 | 12:23 PM
tbird6's Avatar
Good job I think you found the problem.
Sometimes it is just a small thing and in your case nothing was actually wrong with the car. Just needed a hose reconnected.
Old Dec 22, 2015 | 01:10 AM
anthawk's Avatar
yes but I am still wondering it only showed bank 1 as running lean and not bank 2 aswell
Old Dec 22, 2015 | 02:13 AM
JagV8's Avatar
After a few decent runs see what the trims are in case you've another problem.
Old Dec 23, 2015 | 01:40 AM
anthawk's Avatar
yes I have heard that it can take up to 10 miles for the long term fuel trims show acurate readings I will take it for a good run after christmas and check the fuel trims after the run
Old Dec 23, 2015 | 02:06 AM
JagV8's Avatar
After a fuelling-related repair you can force a relearn by a hard reset.
Old Dec 23, 2015 | 12:37 PM
anthawk's Avatar
ok will give that a go before I drive it again
KarmaPolice
35
Mar 17, 2016 08:05 PM
FreshVinceOfBelAir
Dec 14, 2015 01:21 PM
philwarner
Dec 2, 2015 01:25 PM
Pale340
Nov 27, 2015 08:08 AM
mrplow58
Nov 26, 2015 05:29 PM
