antifreeze leak
Old Nov 4, 2009 | 02:52 PM
03styper120k's Avatar
Default antifreeze leak
Hi all im new to forum ! great to find some jaquar buddies
here is the problem i have a 03 stypeR with 120k on it has a antifreeze leak after it warms up and has been driving for a while like 30 min it leaks out of the top of the motor intake area and then runs out on rear of motor down back side of motor to road ,
it looks like the leak under supercharger in rear or under there somewere
any clues ????
Old Nov 4, 2009 | 03:51 PM
tbird6's Avatar
Lots of hoses because of the intercooler plumbing!! I would pressure test the cooling system when cold. Much easier to look for leaks if the engine is not burning hot. Most auto parts stores have a tool loan program. Usually this will include a coolant system pressure tester. I know the local AutoZone does.
Has any cooling system maintenance ever been done? The coolant should be changed every 5 years minimum. Be sure and flush the system thoroughly. Also change your thermostat and degas bottle cap. I would plan on doing all of these when you find the leak.
Old Nov 4, 2009 | 06:07 PM
Default dealer
i dont have a garage as yet so i got to take it to dealer tommorow am the misses drives it and now we have a rental , just had water pump replaced at a shop they thought it was the problem but no go
**this sucks big time even if i had a pressure tester im sure the leak is related to the intercooler or hos etc no t easy to get to , ilo see how bad the dealer reems me
Old Nov 11, 2009 | 09:03 AM
Default dealer quote S/C belt not made anymore ?
well of course there saying its leaking under super charger , its been there for 5 days give me a break ,
\dealer quote we cant change serpentine belt unless we change alltensioners to update the , this belt has been superceded no longer make it ?
Old Dec 6, 2009 | 11:11 AM
Default repaired at rockville md jaguar
Well the dealer repaired the leaking hose under the S/C and all good
It took them a week (I can live with it ) not that great said they had to order parts .
They also replaced EGR valve
1 I now have a driver side window that doesn’t go up automatically anymore
2 rear windows no longer defrosts
3 passenger muffler hangers is separated
Very strange how 3 new problems exist after leaving dealer?
Old Dec 6, 2009 | 01:04 PM
JagV8's Avatar
Take it back, point out the new faults, get them to fix them.
Old Dec 6, 2009 | 03:24 PM
jagmadjohn's Avatar
you think you had problems with your dealer, have a look at this thread
http://www.jaguarforum.co.uk/viewtopic.php?f=16&t=27765
Old Dec 9, 2009 | 12:07 AM
whiteSTR's Avatar
I think you broke the same exact hose that just broke on my R. I haven't fixed it yet because I'm mad at it, but its nice to know I'm not the only one. Must be the winter weather.
Old Dec 9, 2009 | 02:41 AM
JagV8's Avatar
03styper120k - do you have any part numbers or the like for the hoses they replaced please? Dare I ask how much they charged (and how the cost was broken down)?
Old Dec 21, 2009 | 05:37 PM
Default leaking hoses
sorry it took a while to get back lost password for a little while.
repair at dealer was like $1776.00
tail pipe clamp corrosian ate through rear bumper frame i fixed this by exstending bracket higher to better aluminum were there was already a hole in this bumper support .
Old Dec 22, 2009 | 02:42 AM
JagV8's Avatar
Thanks. Could you post the part numbers please? (Including any O rings/gaskets etc.) They may help others who have the same trouble.
ejjbee
Jan 26, 2019 11:53 AM
drpsmith
Oct 16, 2015 08:23 AM
ahunt4
Sep 25, 2015 03:43 AM
Tim Goz
Sep 17, 2015 09:11 AM
kevo
Sep 8, 2015 09:45 AM
