bearing shell tightening torque jaguar s type 2.5
Old Oct 9, 2021 | 03:06 PM
cryptokayn's Avatar
Unhappy bearing shell tightening torque jaguar s type 2.5
Hello I bought new bearing shell for my Jaguar s type V6 2.5 2002, VIN : M60008, and I was looking for the correct tightening torque when remounting the bearing shell on the crankshaft, I have 6 pistons so 2 bold on the bearing support per pistons.
Can someone help me ?
Old Oct 9, 2021 | 04:00 PM
motorcarman's Avatar
I converted my paper copy of the ENGINE COURSE 168 to .pdf years ago.
The document has both the V8 and V6 engine specs and procedures.
Large file but everybody on the internet seems to have it.
I sent it to GUS at jagrepair.com so he will have it.
Old Oct 9, 2021 | 04:36 PM
cryptokayn's Avatar
oh thank you motorcarman
can you send it to me please, I will appreciate it ?
I really need it, I'm struggling to find some doc on the internet
Old Oct 9, 2021 | 05:20 PM
User 42324's Avatar
He told you where to find it. Did you look there ?
http://www.jagrepair.com/images/Auto...Code%20168.pdf
Old Oct 9, 2021 | 05:56 PM
cryptokayn's Avatar
Ok thank you, I saw the document, but it looks like no information is given about the torque for the bearing shell to the connecting rods, even I saw the schema.
Old Oct 9, 2021 | 06:47 PM
User 42324's Avatar
If the 3.0 litre engine specs help, then go here:
https://www.jaguarforums.com/forum/x...-values-37355/
Old Oct 9, 2021 | 07:04 PM
cryptokayn's Avatar
i had a bug so I changed this one, I can not delete
Old Oct 9, 2021 | 07:29 PM
cryptokayn's Avatar
im just missing the torque for the bearing shell
thank you but the link you gave me doesn't help cause its not the same part which is concerned, I need infos for this part, I have 6 pistons, so 12 bolts to connect the bearing shell to those pistons, 2 bolts per pistons, I just need the torque for those bolts
Old Oct 10, 2021 | 07:02 AM
cryptokayn's Avatar
I'm looking for the torque for this parts on my jaguar s type 2.5 V6, and the correct sequence this picture is from a Land Rover, but I need the bearing rod torque for the same parts. there are also 12 bolts cause it's a V6 2002 2.5? VIN M60008.
Can you help me with this Robinus ?
Old Oct 10, 2021 | 07:24 AM
cryptokayn's Avatar
I'm talking about those bolts, I need the torque for those 12 bolts and the correct sequence
Old Oct 10, 2021 | 08:59 AM
User 42324's Avatar
All I found were the torque settings for a 2007 Ford Puma 2.5.
Post. #8
https://www.newcougar.org/threads/torque-specs-for-rod-bearings-and-crankshaft-bolts.77253/
Old Oct 10, 2021 | 11:24 AM
xalty's Avatar
stage 1 23nm
stage 2 43nm
stage 3 105 degrees
go to "303-01A Engine 3.0L" for all the other specs
https://www.dropbox.com/s/0ich2xqe37...anual.pdf?dl=0
georgeb
Apr 22, 2022 04:21 PM
liquidreality
Sep 9, 2014 08:08 PM
Jagman99
Mar 8, 2014 09:50 AM
scardini1
Feb 20, 2014 10:09 AM
jaguar.awd
Jan 4, 2013 05:23 PM
