Beeping on start up
Old Aug 15, 2013 | 03:27 PM
ohfrankyboy's Avatar
Default Beeping on start up
Im getting about 20 beeps when I start the engine, it's a 2004 S-type 4.2
No lights on dash or airbag
Thanks!
Old Aug 15, 2013 | 03:59 PM
GT42R's Avatar
Might be an early sign your battery is dying; when was the last time you replaced it?
Otherwise,
Are you have any issues with the shifter? Is the car in Park?
Are you having any issues with the electronic parking brake?
Old Aug 15, 2013 | 04:06 PM
Well I bought like 2 month ago so I myself never changed it, another thing I get sometime is the radio or Cd is stopping then it goes back on
Old Aug 15, 2013 | 04:16 PM
But yeah I think the batterie would be the cause....
Old Aug 16, 2013 | 01:53 AM
JagV8's Avatar
Hope it is because at least that's easy & cheap DIY to change!
Could the shifter not quite be where it should be? (May flash P but otherwise check if cable stretched & check bolts where it fastens to trans.)
Old Aug 16, 2013 | 02:39 AM
thebiglad's Avatar
If you do buy a new battery, put it on charge for 24hrs before installing it in the car. That way, you will be sure of starting off with a 100% battery, irrespective of what the supplier might say.
I put a new battery on mine recently and it took over 24hrs to reach full capacity!!!
Old Aug 16, 2013 | 02:45 AM
jimbov8's Avatar
Big +1 on the above.
Also worth checking the connectors in the engine bay and grounds.
Old Aug 24, 2013 | 01:11 PM
Thanks everyone! Yes it was the battery, it finally died lol
JarodL
Mar 7, 2024 01:39 AM
simo5555
Sep 9, 2015 06:22 AM
Bones
Sep 8, 2015 08:34 PM
tberg
Sep 7, 2015 07:32 AM
Bigvettefreak
Sep 6, 2015 04:27 PM
