Brake problems question
Old Oct 26, 2013 | 02:55 PM
daboss085's Avatar
Default Brake problems question
hey guys have a quick questions about the brakes on my s-type. Sometimes when pressing the brake it will pop in the pedal and it will make a grind noise and will get really stiff for a quick second and then return to normal. Brakes under regular use are fine. Could this be a rotor problem? or something more in the booster or master? thanks.
Old Oct 27, 2013 | 09:49 AM
motorcarman's Avatar
It's called 'ANTI-LOCK BRAKE SYSTEM'
That is not a 'grind' but a rapid succession of modulator valve actuation and pump motor.
Could be normal actuation when a wheel 'skids' or an intermittent fault.
bob gauff
Old Oct 27, 2013 | 05:54 PM
daboss085's Avatar
Thanks for the info, what should be my next step? thanks.
Old Oct 27, 2013 | 09:16 PM
If there are no faults (DTCs) in the ABS module then I would assume that you are momentarily locking a wheel during hard braking.
bob gauff
Old Oct 28, 2013 | 12:37 PM
daboss085's Avatar
thanks again bob, I have the Innova with abs scanner tool, but it did not find any faults. Would I need a Jaguar scanner?
Old Oct 28, 2013 | 02:53 PM
Mikey's Avatar
Stop braking so hard. The ABS is just doing it's job.
Old Oct 28, 2013 | 07:13 PM
daboss085's Avatar
It will do it even when I do not brake hard, its just a intermittent thing. It happened in the parking lot when I was going 5mph... thanks.
Old Oct 28, 2013 | 09:04 PM
Chassis (C) codes can be read with a 'higher-lever' scan tool.
I talked to a shop owner that has a Snap-on scanner with Ford software that was able to read X200 Body and Chassis modules. I don't know if he 'lied' to the scanner and told it to read a Lincoln LS or what????
bob gauff
BrentGardner
29
Dec 16, 2024 12:13 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
Oliver9218
Sep 3, 2015 05:33 PM
tonydbaker
Aug 30, 2015 11:02 PM
nelsonht
Aug 30, 2015 06:01 AM
