CATS/Adaptive Suspension
Old Feb 17, 2015 | 01:19 PM
edankeven's Avatar
Default CATS/Adaptive Suspension
Can anyone tell me how to disconnect the adaptive suspension/CATS from Trunk? Is it a fuse or relay? I know I need to install 4 new standard shocks first. Also I know ADAPTIVE IS AWESOME! Just need to use something cheaper for now, shocks are way worn out and needs it.
Old Feb 17, 2015 | 03:45 PM
abonano's Avatar
The module is in the trunk - left side.
There are 2 harnesses - disconnect both (you will have a permanent CATS Fault message on your dash.
I personally advise against disconnecting the harnesses from the module...
If your looking to disable the shocks only than disconnect each of the connectors from each shock.
Again, you will have a permanent CATS Fault message displayed and the Amber light I believe...
Old Feb 17, 2015 | 06:36 PM
QuartzSTypeR's Avatar
I got rid of the light and CATS System Fault message by unplugging the module on mine.
Old Feb 17, 2015 | 08:17 PM
abonano's Avatar
yes, quartzSTypeR is correct.
To clarify my previous post:
If you have a fault, you need a dealer level reader to read/erase the code.
If you disconnect the 2 connectors from the ADCM module - the CATS Fault and Amber light will go away.
Old Mar 6, 2015 | 10:34 AM
Dubb's Avatar
Where is module located that needs to be disconnected to get rid of cats failure light
Old Mar 6, 2015 | 10:45 AM
JagV8's Avatar
Read rest of thread
Old Mar 7, 2015 | 11:09 AM
edankeven's Avatar
Module is in the trunk on the left hand side. It says ACDM on top and you unplug both plug ins from the bottom. I installed non electronic Gas A Just shocks on my Jag and they are awesome!
tlynch
Dec 31, 2020 01:58 PM
Dutch xjrdiamond
Nov 30, 2019 09:14 PM
dmatthewman
Sep 30, 2015 10:10 AM
ChrisJay
Sep 27, 2015 09:08 AM
