Center console slides back but won`t open
Old Mar 19, 2015 | 08:19 AM
jkallinen's Avatar
Default Center console slides back but won`t open
Just picked up this car Monday and we were trying to figure why the
center console cover will slide back to expose the drink holders, but
that is far as it goes. It won`t lift up it says it should in the handbook.
Afraid we will break it by forcing it to hard. Anyone else had a problem
with their center console not opening ?
Old Mar 19, 2015 | 12:46 PM
tbird6's Avatar
You still must operate the tab to release the lid so it can swing open.
Have you done that? So it does not just lift up. Now I have a 2005 but I think it's the same as your 2003.
Old Mar 19, 2015 | 12:56 PM
JagV8's Avatar
+1, mine is 2004 but yes use the tab
Old Mar 19, 2015 | 01:15 PM
jkallinen's Avatar
Thanks, but after searching these forums I found a fix that was not mentioned. I did
get it open and I took the redneck approach to fixing it. Turns out the cable release
for the lift is broken so I slid it upright and took some electrical tape and taped over
the tabs that were not working. Don`t need them anyways. Now it opens and closes
no issue.
Regards,
Jim
Old May 13, 2015 | 10:11 PM
Aeeo's Avatar
Jim I am in the same boat, console slides back but its stuck close even with using the latch and force. Ive just never been able to open it. Where is this thead about the issue or hidden location of this cable in the latch or console?
Old May 13, 2015 | 10:20 PM
Aeeo's Avatar
Default Arm Rest!
Thanks!
I guess its also called an arm rest!
https://www.jaguarforums.com/forum/s...-locked-82215/
Old Sep 4, 2016 | 02:17 PM
aholbro1's Avatar
Experienced this problem, mended it:
https://www.jaguarforums.com/forum/s...6/#post1529356
BrentGardner
29
Dec 16, 2024 12:13 AM
lobsterD90
Nov 12, 2022 09:51 PM
anthem
Aug 31, 2015 02:01 PM
Andrew McVey
16
Aug 27, 2015 07:21 PM
PinnacleWax
Detailing / Car care
Aug 26, 2015 11:44 AM
