Check Engine Light
Old Jan 22, 2010 | 01:24 PM
MARK's Avatar
Default Check Engine Light
I have a P1111 code and P1646--Fuel Air metering and check engine light on.Can anybody explain what these codes are and are they related to the same issue and what part is bad. I would assume maybe masss air meter or something related to Fuel Air ratio mixture.
Old Jan 22, 2010 | 01:49 PM
joycesjag's Avatar
P1111- Intake Air Temperature (AIA) intermittent high voltage low temperature condition
- loose connection
-open circuit
-faulty AIA
P1646- RH O2 sensor
-short to ground
-short to power
-open circuit
-high resistance
-faulty O2 sensor
O2 sensor located on drivers side (US) the one before the CC
maybe sensors are bad
Old Jan 22, 2010 | 03:01 PM
JagV8's Avatar
Wrong! (sorry to be blunt) P1111 being a P1 code is manufacturer-specific so you need to look it up with care. For jag & Ford it means that the monitors have completed OK and thus is normal. The alternative would be P1000 which means they have not completed - and then you need to find out why (maybe you recently cleared codes or disconnected battery).
P1646 really is an error, however.
First thing: do NOT make assumptions.
Second: codes are best viewed as hints. Only sometimes are they a direct diagnosis.
The meaning of a P1 can depend on the exact year etc of your car, though that tends not to happen much. I am using the 2003MY tables.
Please note that RH is defined to mean: as viewed looking from rear towards front of car.
In this case, it is indeed bank 1 i.e. the RH bank. The upstream (pre-cat) sensor. Or its wiring, or... Remember - view the code as a hint!!
Having to type this at speed so hope I've got it all right
Old Jan 22, 2010 | 04:38 PM
joycesjag's Avatar
Originally Posted by jagv8
Wrong!
Sorry for misleading and wrongful information! I was going off what alldata had stated for an '05 3.0. I had assumed that is what he has engine wise anyways. Ya' know about assuming.........
Old Jan 22, 2010 | 04:49 PM
JagV8's Avatar
No problem! Alldata could even be right for an 05 as jag changed to a newer version of the Denso PCM and for all I know it changed the meaning of P1111. I kinda doubt it, tho. Probably "just" bad stuff in alldata
BrentGardner
29
Dec 16, 2024 12:13 AM
big d
Sep 3, 2015 07:37 PM
niner nellie
Sep 1, 2015 10:53 PM
tony bosco
Sep 1, 2015 02:06 PM
daro31
Aug 27, 2015 09:26 AM
