check engine light removal
Old Feb 4, 2015 | 07:21 PM
Sonspit's Avatar
Default check engine light removal
Is there a way to remove check engine light without a obd tool. I have had codes read which told me all 3 cylinders on the passenger side were misfiring.. I have changed the coils and spark plugs.. but still have the light.. ok want to reset and see if it comes back.
Old Feb 4, 2015 | 11:01 PM
timfountain's Avatar
You can get a reader which can reset codes for ~$20. It is a good investment, especially since you have already paid out way more for new coils....
Old Feb 5, 2015 | 12:18 AM
QuartzSTypeR's Avatar
Some codes are removable by disconnecting the battery for some time (usually 30+ minutes to drain all keep alive memory). Some codes are hard codes and will require a scan tool. You could always call around or swing by a local shop and see if one of them is generous enough to turn the light of for you for no charge since it shouldn't take more than a couple of minutes.
Old Feb 5, 2015 | 01:03 AM
JagV8's Avatar
If the fault is fixed the MIL will self-clear after 3 engine warm ups.
If fault not fixed, it'll stay on.
Old Feb 5, 2015 | 09:52 AM
Sonspit's Avatar
Thanks for your help. It hasn't cleared yet so I guess there's still issues.. gotta get a obd tool
Old Feb 5, 2015 | 10:43 AM
tbird6's Avatar
When you get the codes read for free at the parts place. Have the guy clear everything before he unhooks the reader.
Old Feb 5, 2015 | 11:37 AM
Some places won't do that as its against the law in some states. Of course, one could always ask the employee to just borrow the scan tool or there's always the "Hey, look over there!" and then clear the codes.
Old Feb 5, 2015 | 01:16 PM
tbird6's Avatar
It's funny you say that because I had a parts store guy tell me that once. I can't find anywhere that it's against any law to erase the codes?
Maybe there is but I can't find it. I finally figured out the guy simply did not know how to do it. I showed him on the reader and then it was no problem.
For troubleshooting it seems almost a must to be able to clear everything and start over.
Old Feb 5, 2015 | 05:58 PM
Sonspit's Avatar
I got the codes cleared at auto zone.. the lady told me "shhhh" lol.. only code there now is p1000. No check engine light.. let's see if it remains that way.. Because before it was cleared there was one new code.. misfire on #1..smh
Old Feb 5, 2015 | 06:28 PM
Sonspit's Avatar
Never-ending...shut the car off. Started it to go to the store, low and behold.... There's the Amber check engine light once again
Old Feb 6, 2015 | 05:33 AM
JagV8's Avatar
You need to fix the fault. That's what the code's been saying and will go on saying. Meanwhile you're causing poor mpg and gradual damage to cat conv
Old Feb 6, 2015 | 03:27 PM
Sonspit's Avatar
Ok, got it scanned again today.. no more misfire codes.. only p1646? And p1000 .. what is this? Auto zone had no info for the p1646.
Old Feb 6, 2015 | 03:43 PM
JagV8's Avatar
You need to look it up for your specific car type (see below). It's in JTIS - free download.
Old Feb 6, 2015 | 04:55 PM
tony1963's Avatar
P1646 - Washer Fluid Contamination
Old Feb 6, 2015 | 05:20 PM
abonano's Avatar
P1646 - Oxygen Sensor - Bank 1 Sensor 1 (heater circuit fault) replace the sensor after checking the connector and wiring harness not being burnt by the exhaust.
Old Feb 6, 2015 | 05:42 PM
JagV8's Avatar
Wow, so helpful.
Where are the admins??? Time for a ban?
Old Feb 6, 2015 | 09:19 PM
Sonspit's Avatar
Looking online for replacement oxygen sensor.. I see one listed" upstream" and one is "downstream" which one would I be replacing?
If it's not too much to ask.. can you take a quick picture of its location.
Old Feb 6, 2015 | 10:31 PM
Upstream.
Old Feb 7, 2015 | 09:55 AM
abonano's Avatar
Originally Posted by Sonspit
Looking online for replacement oxygen sensor.. I see one listed" upstream" and one is "downstream" which one would I be replacing? Thanks If it's not too much to ask.. can you take a quick picture of its location.
Hi, if it wasn't the dead of winter here I would be more than happy to provide a pic - but it's chilly outside. The O2 sensor you need to change is the one that comes right off the exhaust manifold.down pipe going to the converter.
Old Feb 7, 2015 | 01:23 PM
leaping cat's Avatar
This is what you need (if you have a pre 2002 car):
Amazon.com: Denso 234-4046 Oxygen Sensor: Automotive Amazon.com: Denso 234-4046 Oxygen Sensor: Automotive
But I see now that you don't. Sorry.
