Dextron III?
ESSO 999 is the Jaguar recommended fluid. I would guess that MERCON fluid for the Ford would be the same. Ford Explorers used a similar gearbox. I don't know what is available in your part of the world.
bob gauff
bob gauff
Thanks,
Yes, MERCON V is part of the casting next to fill hole, however i sourced a bulk quantity of Dextron III.
What was wrong with your transmission? - I just replaced my prestroke 4-3 which was smashed in 4 pieces - but the "judder" problem still exists in low gears.
Thanks,
Thanks,
OK, well we get ATF produced by Comma which complies with both Dextron III and Mercon V...it's a 12 year old tranbox now but might consider adding a friction lubricant.
Could I ask how much your replacement shaft cost? I did consider the solenoid as a possible failure - the theory being that my broken prestroke spring damaged A,B, OR C.
I'm getting all gears now but when hot, and pulling off the car judders as though the clutch is not meshing properly. Baffled.
jagent
Sep 7, 2015 05:00 PM
