Does anyone need help S-Type!?
Old Mar 2, 2016 | 06:11 PM
edankeven's Avatar
Default Does anyone need help S-Type!?
Here is the work I have done, if anyone needs help I would be glad to pass it on. I have received a lot of help here myself. (2000-Jag-S Type-3.0) If I have not listed what your looking for feel free to message me and ask.
1. Intake manifold gaskets and valve cover gaskets.
2. Spark plugs and coil packs (all 6).
3. 2 din aftermarket stereo install.
4. New shocks (all 4).
5. Replaced both catalytic converters.
6. control arms, tie rods and so on.
7. Door panels and misc. trim replacements.
Old Mar 2, 2016 | 06:28 PM
ZenFly's Avatar
#5) What cats did you use ? How long have they been in and and how are they working out? Did you have 0420 and 0430 codes?
Old Mar 2, 2016 | 09:32 PM
kr98664's Avatar
I'd be especially interested to hear about replacing the shocks. I have to tackle that soon. Perhaps start a new thread on the subject? This might help reduce confusion in this thread if multiple topics get discussed.
Old Mar 3, 2016 | 07:49 AM
aholbro1's Avatar
EdanKeven,
You could do a write-up on each procedure and link each to the appropriate line-item in your original post.
Here's an example from the X300 forum:
Renew coolant with Zerex G-05 and ensure water valve is working freely: https://www.jaguarforums.com/forum/s...winter-102192/
Renew crankshaft damper: https://www.jaguarforums.com/forum/s...74/#post802973
Renew Idler pulley: https://www.jaguarforums.com/forum/s...87/#post809926
(freshly discovered) Renew crankshaft front seal: https://www.jaguarforums.com/forum/s...enewal-101564/
Install Gonzo's Hoodliner my wife got me for Christmas: https://www.jaguarforums.com/forum/s...98/#post798739
Renew bonnet struts (complete, but nothing to see here, no pics, no thread)
Renew Headliner
Stop sunroof rattle
Repair sunroof - it reverses when 3/4 closed, unless I stop it, then re-start it to close.
Repair Seat heaters: https://www.jaguarforums.com/forum/s...s-help-101802/
Repair Driver's seat leather: https://www.jaguarforums.com/forum/s...lstery-101125/
Renew Engine Oil and filter
Renew bootlid struts
Clean and condition leather with Gliptone
I'll update later when I can claim more progress....
I should probably put the hood back on before I go broke!
Renew Upper Radiator Hose: Not much to see, here - straightforward, there's a pic in the Lower Hose Renewal link
Renew Lower Radiator Hose: https://www.jaguarforums.com/forum/s...enewal-101914/
Tinker with Heater Valve: https://www.jaguarforums.com/forum/s...winter-102192/
Renew Drive Belts: https://www.jaguarforums.com/forum/s...e-belt-102387/
Well, that was bust! Here's the original thread...in which the links work fine, but I wasn't smart enough at the time to put it up-top..they are buried pretty deep in the thread below the photos:
https://www.jaguarforums.com/forum/x...roject-100618/
Old Mar 3, 2016 | 08:02 AM
joycesjag's Avatar
^^^heh heh^^^ amateurs
Zane, it would have taken me all day to type that. I think I would have smashed my puker if all those links "were not found".
Old Mar 3, 2016 | 09:11 AM
edankeven's Avatar
Yes had those codes. I got mine from eBay for $150 each, but I'm in California. If your in New York or Cali-First go to website below and enter your cars info. It will give you a list of approved cats for those stated and you just type catalytic converter in the search engine along with the manufacturer part number and it will bring up the cats you want. If you live in any other 48 states just type your car info in Google search or eBay and you will find plenty of compatible cats to choose from that are under $150.
As far as the work goes, there are 2 bolts above the cat towards engine area, and then along the pipe 2 more bolts halfway down muffler. Knock it with something and you can pull the pipe off. Use a reciprocating saw to cut off old cat and either weld new one on or if you have to use some chemical weld or bond and some muffler tape and muffler clamps. I would recommend a weld lol. Does that answer your questions?
Old Mar 3, 2016 | 09:15 AM
edankeven's Avatar
OK so I purchased NON-electronic KYB gas-a-just-shocks off ebay, $250 for a set of 4( they feel pretty good). It was fairly easy removing the old, just disconnected the bolts hold it on and had to disconnect top end of tie rod that was in the way of the bolt holding bottom of shock. I rented a spring compressor from auto store and manually compressed spring, inserted new shock and installed. Compressing the spring took forever by hand so hopefully you have an air gun to speed it up. Also if your using non electronic shocks remember to disconnect the module located on passenger side of trunk.
Old Mar 3, 2016 | 09:17 AM
edankeven's Avatar
Originally Posted by aholbro1
EdanKeven,
Renew Headliner
Stop sunroof rattle
Not sure how to do the links
Old Mar 3, 2016 | 12:14 PM
aholbro1's Avatar
Heh heh Rick...I don't know when/how it switched to all the slashes and internet geek stuff...when first constructed, one of the links, for instance said "Timing Cover Seal Renewal" instead of all the internet gibberish... and others likewise, thread title instead of "PoundSignQuestionMarkStarExclamationPoint!" (PROPS to Kevin Fowler) in this case, I just copied that section of my post and pasted it here, so no real time spent in typing. As I said, they still work in the post, just not when copy|pasted into another post, apparently.
Whoa hoss! That'd be a creative way to shoot a coil across the shop and do some real damage! OK, so no real problem initially, while the shock is still running up through the middle of it...but before removing it, make sure those two compressors are about even and spaced 180 degrees apart - directly across the spring from one another. Otherwise...duck and cover! And if you discover you need to compress it further once the shock is removed, for whatever reason...take it easy..small turns keeping each side even.
Easy-Peasy...just select the address in your browser address bar. Copy. Paste into your thread, and Bob's yer Uncle!
Never tried self-linking to the thread I'm posting in, but here goes https://www.jaguarforums.com/forum/s...7/#post1414688
Old Mar 4, 2016 | 03:36 PM
edankeven's Avatar
ha ha yep true. I did it slow by hand and even on each side. Was scared the coil would shoot right threw me.
Old Mar 4, 2016 | 03:38 PM
edankeven's Avatar
This on ebay fits mine
Catalytic Converter-CalCat Universal Converter Right Walker 82631
Old Mar 4, 2016 | 09:21 PM
Gus's Avatar
Gus
You can find information on the items listed in the How to Guides on this forum or you can look on my page. I hope this helps.
Link to the How to Guides https://www.jaguarforums.com/forum/s...-guides-41364/
Old Mar 6, 2016 | 05:42 PM
Gillian's Avatar
Default Petrol door closure broken
Hello,
I am probably repeating a known issue, ( sorry!). All I need is the bit that flicks out when you push the petrol cap button. I have no idea what the part number is and not very online techy.
So here I am, online....
It appears that it may be a design flaw on the 2005 S-Type. Does anyone have any updates as to whether it's been addressed? What's my best fix here?
Much Appreciated
Gillian
Old Apr 14, 2016 | 03:31 AM
supaman557's Avatar
Default Help needed.
Hello, I have a 2002 s type 3.0.
The driver side window doesn't work. The heater doesn't work, and seems to be moisture in the glovebox, and the passenger side floor was wet. I would appreciate any DIY knowledge.
Old Apr 15, 2016 | 04:08 AM
edankeven's Avatar
Need more info please, does the air conditioning work? It's very common to replace heater control valve. How does the window not operate? Did you check all your fuses?
edankeven's Avatar
http://jaguarclimatecontrol.com/diagnose/
Old Apr 15, 2016 | 05:21 AM
supaman557's Avatar
The air conditioning works fine. Not sure about why the window does not work. Didn't check the fuses, I was just told that it needed new window regulators.
Old Apr 17, 2016 | 09:20 AM
clubairth1's Avatar
Community Influencer
Start a new thread with a title that matches your problem as this one is a mess.
Old Apr 18, 2016 | 09:40 AM
edankeven's Avatar
Prob heater control valve
Old Apr 18, 2016 | 09:53 AM
Mikey's Avatar
Yes. Tag-alongs never get seen.
