Dont Light A MATCH!!!!!!
Old Aug 27, 2009 | 04:42 PM
floppy's Avatar
Default Dont Light A MATCH!!!!!!
My wife for some time has been complaining about a gas smell for the first day after she filled up. So today I went and filled the car myself, when I came out of the station to pay there was gas cascading onto the ground. It stopped after about a minute or so...
What could this be...and is ther any way to drop the tank easlily????
Any help would be much apreciated.
Old Aug 27, 2009 | 05:20 PM
floppy's Avatar
Sry forget to tell you what it is..
2005 S-Type 3.0
Old Aug 27, 2009 | 05:54 PM
Thermo's Avatar
Veteran: Navy
floppy, I would be venturing to guess that you have a small hole in your filler neck hose. To visually inspect the hose, you will need to pull the passenger side rear tire and then remove the liner that is inside of the wheel well. This should give you room to look around most of the hose. If you have recently filled the vehicle, you should also see a small trail of where gas has been spilled. You should be able to follow this trail back to the source. It can also be possible that you have a small return line that has developed a leak.
If you can't visually see the hole, then you may need to get the rear end of the car up in the air and then add a little bit of a gas at a time and see if you can spot where the leak is coming from with fuel actually coming out. Just make sure that you maintain one hand in contact with the car at all times to make sure you remain at the same potential as the car. One little spark from static electricity with fuel around can lead to big, big problems.
Old Aug 27, 2009 | 06:00 PM
whiteSTR's Avatar
Have a fire extinguisher handy as well.. I had an experiment like this go seriously wrong in my old car and it resulted in a toasted hood. Took me 3 minutes to put the fire out by throwing my body on top of the carb..
Old Aug 27, 2009 | 07:17 PM
joycesjag's Avatar
Eric somehow that doesn't come as a suprise to me!
Old Aug 27, 2009 | 08:05 PM
Jon89's Avatar
There is a gas tank recall on the 2005 S-Type models. Ours was replaced just before we purchased the car last December. Get your VIN number handy and call your Jaguar dealer. The symptoms are exactly what you described - fuel spilling from the tank or fill neck....
Old Aug 28, 2009 | 08:55 AM
floppy's Avatar
Ok...
I called jaguar, and they informed me that my particular car was not part of that requal, or the work had already been done.
As for a leak in the filler tube, I dont think thats it because the leak is on the drivers side (opposite the filler tube). Is it possible that the seal around the fuel pump may be gone and if so is there any access to the fuel pump?
Old Aug 28, 2009 | 09:34 AM
Jon89's Avatar
The fuel pump is inside the gas tank. Access to it is by removing the rear seat.
Jaguar blew you off. Either "the work has already been done", or it hasn't. If it has been done, they would have a record of when, where, and by whom.
I just checked my records. The gas tank recall number is R176D. It is typically performed when the customer complains of leaking fuel, not always from the filler tube area, sometimes from the tank itself. So if your tank has been replaced, there would be a record of this recall number with your car's history....
Old Aug 28, 2009 | 11:32 AM
JagV8's Avatar
If you called a dealer.... maybe call another or Jaguar Corporate.... if you call Corporate and they ultimately confirm you needed the recall but it wasn't done - er, complain I think!
You may have 2 fuel pumps: one pumps tank-to-tank and the other pumps out of the tank its in. Jon89 told you how to access it. I don't know where the fuel pipes are then routed. Be exceedingly careful with petrol. Even a "small" spark from (say) a door switch could ignite a petrol/air mix.
Old Aug 28, 2009 | 11:37 AM
Disco stu55's Avatar
haha, no victory without sacrifice i guesss
Old Aug 29, 2009 | 07:40 AM
floppy's Avatar
Success!!!!!
I got the back seat out and found the access panels underneath. When you get under there there there is a round plastic cap (aprx. 6") held onto the top of the gas tank with a hard plastic rim clamp that is in turn held down by a hose clamp.
The plastic ring had crack alowing gas to spill all over the place.
A word of wisdom for anyone who has to tear into this.....
The hose clamp is not what it seems, some brilliant engineer somewhere decided to put a smooth cap over the adjustment nut for the hose clamp. It took me better than an hour to figure out that this cap wasnt some sorta special tool fitting. Take plyers to it and just pull it off, it doesnt come easy but it does come off.
Thanks to everyone for all of your help. This board is great!!
:i con_hyper::ico n_hyper::icon_ hyper::icon_hy per::icon_hype r:
Old Aug 29, 2009 | 10:03 AM
tbird6's Avatar
Does it look like this maybe?? This is from a Lincoln LS.
Old Aug 29, 2009 | 11:42 AM
floppy's Avatar
Yes just like that, with only one exception that I can tell.
On my tank only the passenger side has any hoses or wires coming out of the cap. The one on the driver side gives you acces to what im assuming is some kind of level indicator.
Old Jun 8, 2011 | 03:02 AM
smkjunior's Avatar
floppy, how did you take out of the clamp? I had tried so hard and gave up last time. I thought there's not enough space to pull that clamp out. I spent +$300 for replacing that plastic cap.
Old Jun 10, 2011 | 04:27 AM
floppy's Avatar
I had to use a pnumatic 1/4 inch driver to get at it. It was not fun at all.
Old Jun 10, 2011 | 09:00 AM
Brutal's Avatar
If you tank was repaired/replaced/checked under that recall it would not have those factory installed caps. Pm your last 6 of your vin and ill look and see if it was done. I had 1 last yr from california that showed it was done and it wasnt, and the tank flange was leaking gas too
Old Jun 11, 2011 | 02:13 AM
smkjunior's Avatar
floppy : I should check this thread before fixing my car. Thanks though.
Brutal : I already did before fixing. The dealer told me that my car doesn't have any open case. He said this means my car already got treated. Too Bad.....T.T
Old Jun 11, 2011 | 06:39 AM
JagV8's Avatar
What do they mean "open case"? My guess would be: "it won't be free but your car may need the fix".
Possibly even: "we don't care".
I'd take Brutal up on his kind offer!
Old Jun 14, 2011 | 08:37 AM
Brutal's Avatar
Brutal : I already did before fixing. The dealer told me that my car doesn't have any open case. He said this means my car already got treated. Too bad.....t.t
friggen idiot, he should have said the recall has been done and that recall cannot be done at no charge again. But we need to look at your car and determine where/why its leaking gas!!!! Is thaat too much for an advisor to get??
I would be leary of the cap on the hose clamp still since when we did them we took off the caps and tossed them. Then you remove the tank caps and use special jaguar jigs to measure the opeing for the proper size which is what the recall was for. If it passed you fit new seals and tightened back up. If it didnt pass you replaced the whole tank assembly. And like i said in a previouse post i had a car that was shown to be done by a dealer in california and it wasnt. We got our area manager involved and he called the amm in cali and talked to him about it and the dealer that showed to have done the recall. Unfortunalty in every business youll have people that say they did the work and didnt just to get the money
Jpav27
Jul 31, 2022 06:43 AM
XJsc-guy
Nov 23, 2015 01:56 PM
redrover41
23
Sep 25, 2015 01:33 PM
hoodun
Sep 14, 2015 01:26 PM
avern1
Sep 8, 2015 06:25 PM
