Dreaded "ABS Fault ....No DSC available" showing
Old May 28, 2014 | 09:00 AM
trashdi's Avatar
Unhappy Dreaded "ABS Fault ....No DSC available" showing
I took my Jag to dealer to read the code...and he came back with replacing passenger rear bearing ( $241) as fix.
The car triggers the ABS shuddering at low speeds and its very unnerving.
Should have consulted you guys first...I jacked up the car to find the front passenger wheel hub assembly damaged at sensor cap so I replaced the hub assembly. ( don't know how the dealer missed that one) ... Still the ABS fault message... Reading some other posts here I cleaned the rear sensors and sensor wheels ...I have also replaced my 9 year old Battery ...but still the ABS fault message .....Maybe the Jag dealer is right..it is the rear bearing ?? I have checked the rear wheel when the car was jacked up ........the bearing felt okay when I tried to move the wheel....no loose movement or rattle.....wheel moved with no sound......Could use some input from the experts ...Thanks.
Old Jul 9, 2014 | 07:31 PM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Did you ever resolve this problem?
Old Jul 10, 2014 | 09:02 AM
trashdi's Avatar
No the problem exists ...the ABS shuddering has been minimal now , but the code still displays.
Old Jul 10, 2014 | 11:27 AM
tbird6's Avatar
What is the code?
Old Jul 18, 2014 | 03:43 AM
P700Dee's Avatar
Why have you not changed the sensor ? You can swap left to right see if the fault moves.
Old Jul 26, 2014 | 05:00 PM
Default Bearing/hub/sensor assembly probably should be replaced.
My mechanic determined my front left ABS speed sensor was bad. Replacing the bearing/hub/speed sensor assembly ($196 from NAPA; RockAuto.com sells them for even less) resolved the problem. No more codes & dash lights. Worth the $$.
The bearing/hub/speed sensor is sold as an assembly so if your speed sensor fails the solution is to replace the entire assembly, which your dealer is referring to as the bearing. If you try to replace the sensor alone you will find that they are difficult to procure and actually cost MORE than the full assembly that includes new bearings and hub in addition to the sensor! I'd recommend you have the work done that the dealer suggests if you really want the problem to go away.
Old Sep 26, 2014 | 12:15 PM
mwaggon's Avatar
Default ABS sensor
Any chance you can use the speed sensor from Lincoln LS on the S-type? I have seen many parts will cross over and the price difference on this is substantial. Not to mention that my S-type has like 205K mi on it and I don't want to bleed tons of money into it.
Matt
Old Sep 26, 2014 | 01:01 PM
tbird6's Avatar
You will need to check it out. Buy the LS part and you can return it if it won't fit.
Old Sep 26, 2014 | 06:51 PM
Dennis Catone's Avatar
I get the DSC not available message every once in a while, then it goes away. Is there any harm to the car in driving with DSC not available? I have been driving without it my entire driving life so it is not a personal requirement.
Old Sep 27, 2014 | 01:52 AM
JagV8's Avatar
It's just a warning that a safety feature has been disabled.
Cars never used to have the feature. There again, the vast majority of drivers probably need it!!
Old Sep 27, 2014 | 02:22 PM
NikolaiDiqnov's Avatar
If the warning light is on you still have brakes, only the ABS system does not operate properly. If you have the problem I would recommend to check the battery first, then disconect the sensor and clean it. And if these actions do not solve the problem, then replace the sensor. In some cases the sensor is just covered in mud and other substances.
Old Sep 27, 2014 | 05:01 PM
Thanks, where is the sensor located? Easy to get to?
cissdm
May 3, 2016 06:02 AM
skyryder
Mar 25, 2016 08:18 PM
scooternva
19
Oct 27, 2015 02:14 PM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
