Drivers seat memory
Old Jan 11, 2012 | 10:48 AM
roadrunner's Avatar
Question Drivers seat memory
Hi hope one of you chaps can help me?
My drivers seat has stopped working auto on entry and exit! I can still move it manually up and down back and forth but it is a nuisance. I have bad legs and am finding it a problem. The steering wheel is still working on it's memory and is set to auto.
I have tried to reset the memory no luck at all. I am still using the same key.
Regards Brian
Old Jan 11, 2012 | 12:13 PM
Welcome to the forum Brian,
What year is the car? I assume it's an S Type?
Old Jan 11, 2012 | 12:39 PM
roadrunner's Avatar
Question
I shougd have said! Jaguar S Type 2003 6speed auto 2.5 petrol.
I beleave it is a common problem, been fine untill now.
Old Jan 11, 2012 | 12:43 PM
roadrunner's Avatar
It is an S Type 2.5 petrol 6 speed auto se 2003. Has been fine until now, I believe it is a common problem?
Old Jan 11, 2012 | 01:17 PM
JagV8's Avatar
Common? I'm not convinced but if it is then Search will get you other threads.
Old Jan 11, 2012 | 01:44 PM
GoKittyGo's Avatar
My 05 has what I call a gremlin. Sometimes it won't work, but if I turn the car off for a 10 count and start it pack up it works fine. I've only had it happen like twice though.
Old Jan 11, 2012 | 02:06 PM
police666's Avatar
i believe the amount the seat moves back when you remove the ignition key is only 50mm if you cant get it working can you set memory 1 for normal driving and memory 2 for entry / exit ?
Old Jan 11, 2012 | 05:14 PM
roadrunner's Avatar
Hi yes I have tried that, it will not move on any memory 1 or 2 I have also checked for any loose connections under the seat it really has me beat. I have had a major operation and I am finding it awkward just when I need it most, I will try and solve it for a week or two then I will just have to let my dealer have a go.
Old Jan 11, 2012 | 05:54 PM
police666's Avatar
you could try doing a reset by disconnecting the battery for about 30mins but i'd chheck with others on here 1st before doing that.
Old Jan 12, 2012 | 04:29 AM
roadrunner's Avatar
Before I try and disconnect the battery and then reconnect. Is it possible that the battery could be run down due to little use of the car while I was in hospital? Although it does start OK.
Brian
Old Jan 12, 2012 | 05:52 AM
I doubt this is going to be a battery problem, more likely a module if all the connections and cables are good.
So a reset may help, you'll need to reset the clock, one touch windows etc afterwards and you'll need the radio code as you're in the UK.
Old Jan 12, 2012 | 06:35 AM
roadrunner's Avatar
Many thanks for all your suggestions and help. I will have a few more tries at it before taking to a dealers but I suspect that will be the outcome.
Very grateful for info sent and still open to suggestions.
Regards Brian
Old Jan 12, 2012 | 05:29 PM
penjags's Avatar
Brian,
You will see from my post today I've been investigating this part of the S-type electrics in some depth. There's a Technical Bulletin which you will find helpful to diagnose your fault - S501-14. I found a link to it on the forum.
Peter, S. Wales
Old Jan 13, 2012 | 06:31 AM
roadrunner's Avatar
Hi Peter I have looked but I cannot find at all, do you have a link?
Brian
Old Jan 13, 2012 | 06:55 AM
Here it is, this applies to 1999 on, maybe someone can confirm if it is good for the facelift models post 2003 also?
Old Jan 13, 2012 | 10:13 AM
roadrunner's Avatar
Now this looks OK will have a go this weekend.
Brian
St.Regis
Oct 4, 2024 12:07 PM
Clamdigger
Sep 12, 2015 03:43 PM
jagent
Sep 12, 2015 09:10 AM
bavareze
Sep 11, 2015 01:49 AM
joey g
US Northeast
Sep 7, 2015 06:28 PM
