View Poll Results: Can STR EGR valve be replaced without removing supercharger and throttle body elbow?
Yes
50.00%
No
50.00%
Voters: 2. You may not vote on this poll
Egr valve replacement STypeR
Old Mar 23, 2024 | 03:38 PM
Millarjs's Avatar
Default Egr valve replacement STypeR
I’m getting CEL for lean fuel mixture after repairing leaky fuel rails ( supercharger removed etc)
smoke test for vacuum leaks shows leak around coil casing (?) on EGR valve. Not sure if this a real issue or would it leak in ignition off mode?
I found one available on partsgeek but replacing it is a bitch. Can it be done without removing supercharger and throttle body elbow (groan). ??
thanks for any advice!
Old Mar 24, 2024 | 02:22 AM
bydand's Avatar
If I am reading you right. Would it not be vacuum line seal to the Brake servo which sits on the EGR which is leaking, rather?
C2S15816
https://parts.jaguarlandroverclassic...ml#tab-gallery
https://www.jaguarforums.com/forum/s...-p0174-149418/
Old Mar 24, 2024 | 07:50 AM
Millarjs's Avatar
Default EGR leaking
Thank you. I was able to replace that bushing and it seems to hold pressure ok.
the current leak is in the egr valve assembly or the gasket where it attaches to throttle body elbow. All very tough to get to.
Old Mar 24, 2024 | 11:19 AM
scottjh9's Avatar
The egr valve comes off before the supercharger anyway
Old Mar 24, 2024 | 12:35 PM
Millarjs's Avatar
Maybe I’m doing it wrong but I previously removed supercharger and leaky fuel rails WITHOUT removing the EGR valve assembly
even with S/c removed it was not obvious how to remove EGR valve on back left of engine bay.
I do not wznt to remove S/c if at all possible.
thanks.
Old Mar 25, 2024 | 10:11 PM
xalty's Avatar
thanks.
heater lines out you'll get some room. heat the manifold side nuts and then take the egr side bolts off. this is how you're supposed to remove the blower
the other way of just bending the tb elbow out of the way to get to the bottom bolt is better
Old Mar 26, 2024 | 11:05 AM
scottjh9's Avatar
I went a step further and removed the entire cabin air filter encasement. Tons of room and very little chance of rounding a nut or bolt
Old Mar 26, 2024 | 11:15 AM
Millarjs's Avatar
Default Egr removal
I have already removed under hood brace and cabin air filter trappings. Looking at removing heater hoses as suggested
any intel on why 4 hoses going through firewall?
thanks again
Old Mar 26, 2024 | 11:38 AM
xalty's Avatar
thanks again
dual zone heater core
datc works by impeding flow to the heater via valve it doesn’t have a real blend door
Old Mar 26, 2024 | 12:03 PM
Millarjs's Avatar
Default Heater hoses
On closer inspection I see there are only 3 hoses going through firewall. Makes more sense.
1 supply and a return for each half of the heater core.
again thanks for advice.
Old Mar 26, 2024 | 01:52 PM
scottjh9's Avatar
thanks again
for dual climate control temp settings coming off dccv when seperate pass and driver temps are used. When you disconnect the hoses remove the bracket bolts for the two brackets holding the hoses and fold them towards the front and secure with bungee cord or similar
Old Mar 26, 2024 | 01:59 PM
scottjh9's Avatar
Go to this thread and look at post 163.
S-type supercharger removal (with pics)
just search the title in the search bar. It pops up about fourth one down. I was removing the whole charger so you probably do not have to remove the big intake pipe or throttle body. All the egr access is from the space created on the pass side
Old Mar 26, 2024 | 05:06 PM
Millarjs's Avatar
Thanks. But I’m not good at this thread searching. Was not able yet to find the article with pics ftom my phone. Will try again ftom my tablet but hints are welcome.
Vics2003typeSR
Jul 14, 2019 10:45 AM
thomash85715
Feb 4, 2019 04:46 PM
maniqz
Aug 7, 2017 12:37 PM
SoTxXjr
Aug 20, 2009 12:21 AM
skanoski
May 30, 2008 06:35 AM
