Engaging chirp for factory Jag alarm system?
Old Dec 30, 2013 | 01:45 PM
Jagyouare23's Avatar
Question Engaging chirp for factory Jag alarm system?
Some time ago I recall one an uncle telling me that I could engage a chirp and courtesy flash on the factory Jag alarm on my s-type as opposed to the no chirp with courtesy flash. I was wondering if anyones ever heard of this or something similar?
Old Dec 31, 2013 | 04:07 PM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Try pressing the lock button on the fob 2x's. On my '03 that is how I get the horn chirp. One push just gives visual confirmation with a flash of lights but no audible noise.
I like this feature because there are plenty of times I do not want a confirmation sound when I lock.
Old Dec 31, 2013 | 04:22 PM
ONEsicJAG's Avatar
I've read somewhere that if you press the lock button twice within 3 seconds it puts the car into sleep-mode and reduces the drain on the battery.
Old Dec 31, 2013 | 06:57 PM
Cambo's Avatar
Haven't done this with an S-Type, but with the XJ it can only be programmed with the dealer level diagnostic system (IDS/SDD).
Old Jan 1, 2014 | 09:21 AM
I've never seen any documentation to support this theory.
Old Jan 1, 2014 | 10:02 AM
JagV8's Avatar
I think you'll find 2 pushes tells it to deadlock and enable the ultrasonic alarm sensors and yes puts it straight into at least part of sleep. You'll see it turns off any lights that were on, for example.
IDS/SDD can do various tweaks if you really care. Just pay for what you want, I suppose.
Old Jan 4, 2014 | 03:15 PM
ONEsicJAG's Avatar
Theory Would Imply I'm Assuming. You Learn Something New Everyday.
Old Jan 5, 2014 | 07:47 AM
So true, especially with these cars.
Old Jan 5, 2014 | 08:59 AM
aholbro1's Avatar
John, I don't believe US Spec cars have deadlocking. (Having said that, I don't really know what deadlock is....just read in "Non-US Spec cars only" next to it in the manual. (Or maybe it was "UK-Spec cars only?")
Old Jan 5, 2014 | 10:03 AM
JagV8's Avatar
Oh. Idea is that 2 rapid clicks disable the internal door handles (and unlock button) so any would-be thief can't open any door even if they break door glass. Also can't turn off/bypass the alarm without using a key (or its fob).
It means there's little point breaking in with the hope of driving the car away.
Easy to test: double lock as mentioned (parked, engine off, key out) while still in the car, then try to open door using the door's lever. Over here, door stays locked. Alarm likely to go off. Key in ignition will make it happy again.
Old Jan 5, 2014 | 10:18 AM
Mikey's Avatar
Either way, I believe changing the settings cannot be done without the correct tools.
Old Jan 6, 2014 | 02:17 PM
Interesting idea but, alas, neither my USA '01 nor '03 S-Type behaved as you described after activating the security button. Here's what I learned regarding the security systems in my '01 and '03 US-based S-Types. Some of these features may be dealer-programmable so I can't draw any sweeping conclusions...
For both MYs -
- the security system activates 20 seconds after the security button has been pressed.
- 1 tap of the security button activates security and extinguishes interior and exterior lighting.
- 2 taps in quick succession does as above and also gives an audible chirp from the car's horn.
- activating the security system does not disable the interior lock levers & door handles, even after the 20 second delay; however, opening the doors after the 20-second delay will sound the alarm. If you open the door in less than 20 seconds - no alarm.
- with security activated, moving the interior lock lever to unlock position does not trigger the alarm; pulling the door handle DOES trigger the alarm.
And here's where the cars behaved differently:
- on the '03, simply inserting the key in the ignition shuts off the beeping horn alarm as JagV8 described above; however, this did not work on the '01, which required that I insert the key and turn it to Pos I.
Old Jan 6, 2014 | 05:16 PM
JagV8's Avatar
How odd. The deadlocking feature (activated on 2 quick taps) is handy. I wonder why it's not used on all cars. I've not had a car without it for many years.
Old Jan 7, 2014 | 09:07 AM
My guess is there is some U.S. federal mandate prohibiting deadlocking / immobilizing door handles.
Old Jan 7, 2014 | 11:16 AM
JagV8's Avatar
Could be. Laws vary a lot.
Old Jan 17, 2014 | 04:48 PM
Jurgen Dimmers's Avatar
Hi
I had never known about the deadbold system if I hadn't read about it here.
Tested it on my year 2000 S Type and works.
press the lock button twice within 3 seconds and it"s in deadlock. the doors can't be opened even from inside.
Old Jan 17, 2014 | 05:12 PM
JagV8's Avatar
Excellent.
I was starting to think it was UK only!
Old Jan 17, 2014 | 06:22 PM
plums's Avatar
Probably ever since whichever politician it was dumped his car into the river and his mistress drowned.
Another variant on "think of the children".
Old Jan 18, 2014 | 01:14 AM
JagV8's Avatar
You'd think everything (*) would be banned...
(*) even guns? noooooo
Old Jan 18, 2014 | 07:08 AM
Goes to show how stupid people(politicians) can be,
Which one is most possible to happen:
a child opening the door from inside and running on to the street.
something happening to the car with kids in it.
the drowning mistress.
I think it's a great security option.
