engine trouble
Old Mar 24, 2008 | 04:15 PM
jagxtype's Avatar
Default RE: engine trouble
DIS coil?(Sounds a lot like a coil symptom)Plug Wires (not sure if it is COP)? MAF?, MAP? Vacumm Leak? CPS?
Old Mar 24, 2008 | 04:57 PM
jag_genius's Avatar
i wud look at coil number 6 maybe swap it with 5.. and it also may be that your lower pcv elbow maybe torn.. common on v6 stype.. you will hear a hissing .. and if you wiggle the upper pcv elbow the noise will change a little.
Old Mar 24, 2008 | 05:01 PM
JagtechOhio's Avatar
Yeah, those are coil- on- plug setups, and it may be a bad coil. Let's hope the plug wasn't fouled by an internal fault, which a compression test could shed some light on.
Before things get complicated, you may want to try cleaning the Mass Airflow Sensor with somr CRC brand MAF spray cleaner.
Wait awhile for some additional advie, FactoryJagTech, jag_genius and ibjags are all very knowledgeable on your model and generous with their insight.
Old Mar 24, 2008 | 05:35 PM
jagxtype's Avatar
be careful on these cars using that cleaner. I know that my x type has a plastic MAF tube, and that cleaner will melt it away and ruin it. Unless its aluminum, i would take the element out and clean it that way. Just be careful!
Old Mar 24, 2008 | 07:01 PM
jagx,
Might you be referring to Throttle Body Cleaner? That stuff is way too aggressive.
Old Mar 24, 2008 | 08:52 PM
jagxtype's Avatar
I was referring to the cleaner, i am not sure if it is friendly to plastics or not, but most of that cleaner will harm plastics. You would know better than me, the only ones i have had to clean were aluminum tubes.
Old Mar 25, 2008 | 07:40 AM
FactoryJaguarTech's Avatar
Use brake clean to find the leak. Wontdamage the plastic or rubber.
Old Mar 29, 2008 | 06:40 PM
Where was the vacuum leak?
Swapping coils from 5 to 6 is to see if code comes back on different cylinder. It is on 6 now, if code comes back saying Cyl 5 misfire, then you know coil is bad.
Old Mar 30, 2008 | 11:29 AM
jag_genius's Avatar
if it is fixed it shudnot buck anymore
Wolfy
May 28, 2024 08:06 AM
Jpav27
Jul 31, 2022 06:43 AM
Kevin Burnaby
Jun 28, 2020 08:04 AM
jehart49
Sep 12, 2015 05:36 PM
XJsc-guy
Sep 2, 2015 11:43 AM
