Engineering Test Mode
Old May 30, 2011 | 10:28 PM
cliff328's Avatar
Default Engineering Test Mode
If you want a ton of information, try this. Put the key in the ignition,
and, while turning the key to the II position, press and hold the
button on the left stalk...the one you usually use to advance thru
miles, average speed, etc. The message, ENGINEERING TEST MODE
will appear in the message section of the tach. Now, use the
k/mp button on the left side of the dash to move thru the information.
Initially, each and every light in the cluster will illuminate...a good way
to test all the bulbs. Next, is the gauge test. Keep going and you'll
find actual battery voltage, fuel trims, digital engine temps, etc, etc.
You can use this test mode with the engine running, or, just with the
ignition on, and, you can use it while the car is in motion. You can't
do any harm nor effect any changes, and, when you remove the key,
the cluster returns to normal mode. Enjoy.
cliff
Old May 30, 2011 | 11:23 PM
drec's Avatar
Is there any documentation on this? Is it mentioned in the JTIS?
Old May 31, 2011 | 05:14 AM
joycesjag's Avatar
https://www.jaguarforums.com/forum/s...st-mode-35978/
Old May 31, 2011 | 11:30 AM
JagV8's Avatar
Search provides the details - if you use it
Old May 31, 2011 | 11:50 AM
carelm's Avatar
It's geared towards men obviously. It has blinking lights, whirring gauges and lots of data intuitive to Klingons. You can use it as backup in case your speedo or tach goes belly-up I would think.
Mike
Old Jun 1, 2011 | 06:42 AM
SchultzLD's Avatar
ETM is great, but hard to understand some paramiters. I for one am very interested in IAT's, MAF voltage, TPS voltage, and Timeing curves. I can't seam to find ANY of that info in a understandable format. Please HELP. lol Can some one Barney Style what I'm looking for, and how to read it?
P.S. I can only scroll one way using the info botton on the left stalk, and I don't have to remove the Key to go back to normal operation, I just push and hold the info botton for a few seconds.
Old Jun 1, 2011 | 06:56 AM
JagV8's Avatar
Get an OBD tool - such as elm327
Old Jun 5, 2021 | 03:41 PM
scottyjag's Avatar
Default Another Easter Egg
Thanks for posting this.
Old Mar 9, 2022 | 10:07 PM
armaan__0807's Avatar
Default help
cliff
Can you please tell me how to use it while engine running .... I have use this engineering mode when the vehicle is on ignition but when I turn the car on it exits the mode and just shows the normal tachometer of the car .
Old Aug 28, 2024 | 04:43 PM
kult's Avatar
I am facing same problem, have you solved it?
Old Aug 28, 2024 | 04:58 PM
JagV8's Avatar
What are you wanting to do and why? ETM has very few useful uses.
Old Aug 28, 2024 | 05:10 PM
kult's Avatar
Hi,
RPMs and speedo fluctuating, idle rpm 780rpm on torque app matching cold start rpm on the dash, once reved , stays on 950rpm, but torque says 780 +/- 5.
I eliminated nearly everything, so now I'd like to see if ETM matches torque app, if so, I would blame faulty clocks.
Can't figure out how to start car with this ETM on, it disappears straight after I start the car
Old Aug 29, 2024 | 02:06 AM
JagV8's Avatar
OBD will be accurate (by law). Forget ETM.
Old Aug 29, 2024 | 02:57 PM
kult's Avatar
Understood. Still would love to know how ETM works with engine running
Forcedair1
Sep 8, 2025 01:57 PM
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
scottatl
Sep 4, 2015 08:08 PM
OkieTim
Sep 2, 2015 12:48 PM
