F type rims on a str?
Old Apr 15, 2017 | 01:02 AM
pgrstr's Avatar
Default F type rims on a str?
Has anyone tried f type alloys on the s type r? I know the rear offset is out by a bit..but I want to go 19"s and the aftermarket selection ain't great for 5 x 108 staggered atm imo....
Couple of eBay number suggestions...
162452751920
352025742369
Old Apr 15, 2017 | 01:27 AM
JagV8's Avatar
Sounds like a way to buy trouble.
Old Apr 15, 2017 | 02:31 AM
Datsports's Avatar
according to ferrada wheels they do . funny i was just looking at a set for mine .
apparently the Ferrada FR series can fit 20x9/10.5 FR3 and i expect FR1,FR2,FR4 5x108 +35/38 Jaguar F Type , S Type & XF .
20x9/10.5 Ferrada FR3 5x108 +35/38 Bronze Wheels Fits Jaguar F Type S Type XF | eBay
Old Apr 15, 2017 | 03:28 AM
JagV8's Avatar
Will they be strong enough? The STR is much heavier.
BTW potential insurance nightmare in the UK... Tougher laws still in Germany...
Old Apr 17, 2017 | 01:44 AM
pgrstr's Avatar
There isn't much weight difference between an f type v8 s and a str so I doubt that this would be an issue.
I just wanted to find out if anyone had tried fitting them to an s type chassis??
Old Apr 17, 2017 | 02:01 AM
JagV8's Avatar
The lack of replies says it all.
Old Apr 17, 2017 | 02:09 AM
pgrstr's Avatar
Most helpful...
Old Apr 17, 2017 | 02:19 AM
JagV8's Avatar
It is what it is. People are not doing it.
Old Apr 17, 2017 | 11:08 AM
clubairth1's Avatar
Community Influencer
Are you sure you want 19"?
I find the 18" and 20" tires/wheels to be cheaper and easier to get. Plus a wider selection of models.
Seems like the 19" diameter are not as popular.
Old Apr 18, 2017 | 03:35 AM
Datsports's Avatar
+1^
personally id do the 20'' due to the availability of tires .
18'' are ok . but 19'' is hard work here too .
so to prove two points on the subject here is a link showing bad cattitude's STR with xfr wheels attached .
https://www.jaguarforums.com/forum/s...38/#post758086
then after reading this I'm lead to believe the f type wheels do in fact fit the XF so in turn should fit the s type.
https://www.jaguarforums.com/forum/x...ls-xfr-146861/
also this shows the f type front wheels to be correct fitment to the STR but no info on the rears
https://www.wheel-size.com/size/jaguar/f-type/
Old Apr 18, 2017 | 04:48 AM
Datsports's Avatar
ok more searching came up with this for the f type rears .
no way will the rears fit the s type without a spacer .
you will have better luck with xf wheels i think .
275/40R18 98V
9.5Jx18 ET27 5x108
2.3 / 2.5
275/35ZR19 98Y
9.5Jx19 ET27 5x108
2.3 / 2.5
285/30ZR20 97Z
10Jx20 ET25 5x108
2.5 / 2.7
Old Apr 18, 2017 | 05:21 AM
Datsports's Avatar
Old Apr 18, 2017 | 06:04 AM
pgrstr's Avatar
Thanks for the info gents. Definitely food for thought
