Finished radiator and hose replacement - now MAF and IAT codes 0102 and 0112
So I finished the radiator and hose replacement job, fired up the Jag and I have a P0102 and P0112 code. Both are plugged in properly. When I was doing the work I had the airbox unplugged and stored inside. 02's are reading 1.25 v's, both of them. Tried unplugging the maf, quickly died. According to the ultragauge the MAF seems to be reading close to what you would expect, around 8 g's/sec if holding the throttle open to maintain 2000 rpm, IAT reads close to ambient temperature. So anyone every had anything like this? I hate to throw parts at it and hope it goes away because I have no evidence these are bad other than the codes.
New codes after doing some other work? Definitely don't throw parts at it, as it would be EXTREMELY unlikely for two previously good parts to simultaneously fail. Most likely you're looking at something disturbed during this other work.
Wiring diagrams here, see figures 03.5 and 03.6:
http://www.jagrepair.com/images/Elec...al%20Guide.pdf
The MAF gets power from fuse F37 under the hood. It also powers several other items but I don't think those systems would set a fault until after a couple of complete drive cycles.
Also check the airbox installation carefully, such as for a leak in the intake tube. That's one of the possible sources for a P0102 code:
http://www.jagrepair.com/images/Auto..._OBD_II_R2.pdf
You have an str so there is another stand alone iat in the intake cooler manifold. Possibly located passenger side towards the rear. Make sure it is plugged in or not broken. More than likely is the combo maf iat in the airbox tube by having both throwing codes
RaceDiagnostics
Mar 25, 2014 03:01 PM
